주요 콘텐츠로 건너뛰기
Samsung Galaxy Watch Battery Replacement
필요한 것
  1. Samsung Galaxy Watch Battery Replacement, Opening Procedure: 1 단계, 이미지 1/1
    • Remove the four Tri-point #00 screws (4.2 mm length) on the backside of the watch.
  2. Samsung Galaxy Watch Battery Replacement: 2 단계, 이미지 1/2 Samsung Galaxy Watch Battery Replacement: 2 단계, 이미지 2/2
    • Use an opening tool to get between the back cover and the metal housing of the watch.
    • Carefully pry the plastic back cover open.
    • Don't remove the back cover yet. There is a flex cable running to the core assembly inside.
  3. Samsung Galaxy Watch Battery Replacement: 3 단계, 이미지 1/2 Samsung Galaxy Watch Battery Replacement: 3 단계, 이미지 2/2
    • Lay down the watch and lift the back cover to access the sensor connector on the motherboard.
  4. Samsung Galaxy Watch Battery Replacement: 4 단계, 이미지 1/2 Samsung Galaxy Watch Battery Replacement: 4 단계, 이미지 2/2
    • Use a spudger to disconnect the sensor flex cable from the motherboard.
  5. Samsung Galaxy Watch Battery Replacement: 5 단계, 이미지 1/3 Samsung Galaxy Watch Battery Replacement: 5 단계, 이미지 2/3 Samsung Galaxy Watch Battery Replacement: 5 단계, 이미지 3/3
    • Remove the back cover.
    • When closing the watch make sure the rubber gasket is undamaged or replace it with a new one.
  6. Samsung Galaxy Watch Battery Replacement, Core Assembly Removal: 6 단계, 이미지 1/2 Samsung Galaxy Watch Battery Replacement, Core Assembly Removal: 6 단계, 이미지 2/2
    • Use a spudger to disconnect the display flex cable from the motherboard.
  7. Samsung Galaxy Watch Battery Replacement: 7 단계, 이미지 1/2 Samsung Galaxy Watch Battery Replacement: 7 단계, 이미지 2/2
    • Lift the core unit out of the housing.
    • The core's plastic frame sits tight inside the housing.
    • Carefully thread the display flex cable through the gap of the core's plastic frame.
  8. Samsung Galaxy Watch Battery Replacement, Motherboard: 8 단계, 이미지 1/2 Samsung Galaxy Watch Battery Replacement, Motherboard: 8 단계, 이미지 2/2
    • Use a spudger to disconnect the hall sensor flex cable.
  9. Samsung Galaxy Watch Battery Replacement: 9 단계, 이미지 1/3 Samsung Galaxy Watch Battery Replacement: 9 단계, 이미지 2/3 Samsung Galaxy Watch Battery Replacement: 9 단계, 이미지 3/3
    • Use a pair of tweezers to gently peel both button cables from the plastic frame.
    • The button cables have metal plates behind them. These plates should remain on the cables.
  10. Samsung Galaxy Watch Battery Replacement: 10 단계, 이미지 1/1
    • Remove the single Phillips #00 screw (3.4 mm length).
  11. Samsung Galaxy Watch Battery Replacement: 11 단계, 이미지 1/3 Samsung Galaxy Watch Battery Replacement: 11 단계, 이미지 2/3 Samsung Galaxy Watch Battery Replacement: 11 단계, 이미지 3/3
    • Insert a spudger into the small gap underneath the motherboard where the cutout in the plastic frame is.
    • Lift the motherboard by twisting the spudger.
    • Slide the motherboard out from under the plastic tab.
  12. Samsung Galaxy Watch Battery Replacement: 12 단계, 이미지 1/1
    • Remove the motherboard.
  13. Samsung Galaxy Watch Battery Replacement, Battery: 13 단계, 이미지 1/3 Samsung Galaxy Watch Battery Replacement, Battery: 13 단계, 이미지 2/3 Samsung Galaxy Watch Battery Replacement, Battery: 13 단계, 이미지 3/3
    • Push the battery out of its recess through the cutout in the plastic frame.
    • The battery cable may slightly stick to the plastic frame—pull carefully.
    • Remove the battery.
결론
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery.
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
다른 117명이 해당 안내서를 완성하였습니다.
Tobias Isakeit
회원 가입일: 03/31/14
117,598 평판
안내서 188개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,535개 작성하였습니다
댓글 49개
thank you,it really help alot
Otunla oluwashina - 답글
Where can I buy the battery?
Buzz Burrows - 답글
Where can you buy the battery 42mm version?
Thomas - 답글
We hope to have them in our store soon. Check on our Samsung smartwatch parts over at [[ 잘못된 부품 링크 ]]
Tobias Isakeit -
How much does this cost for a battery and labor
Audrey Snit - 답글
댓글 쓰기
조회 통계:
24 시간 전: 133
7일 전: 938
30일 전: 4,586
전체 시간: 259,071
