주요 콘텐츠로 건너뛰기
Samsung Galaxy Watch4 Classic Display Replacement
필요한 것
  1. Samsung Galaxy Watch4 Classic Display Replacement, Power down your watch: 1 단계, 이미지 1/1
    • Before starting repairs, take your watch off the charger and power it down.
    • Remove the watch band.
  2. Samsung Galaxy Watch4 Classic Display Replacement, Unscrew the back cover: 2 단계, 이미지 1/1
    • Use a Tri-point Y000 screwdriver to remove the four 4.0 mm-long screws securing the back cover.
    • Insert an opening tool into the seam between the back cover and the metal housing.
    • Twist the opening tool to create a gap.
    • Don't try to remove the back cover all the way yet. The sensor flex cable is still connected to the motherboard.
    • Lay the watch face down.
    • Carefully swing open the back cover by folding it to the opposite site of the created gap.
    • Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the motherboard.
    • Remove the back cover.
    • Make sure the rubber gasket is undamaged. If damaged, replace it with a new one during reassembly to maintain proper water resistance.
    • Use the pointed end of a spudger to disconnect the hall sensor-, the display-, and the crown button flex cable.
  3. Samsung Galaxy Watch4 Classic Display Replacement, Unscrew the motherboard: 6 단계, 이미지 1/1
    • Use a Phillips screwdriver to remove the 4.4 mm-long screw securing the motherboard.
  4. Samsung Galaxy Watch4 Classic Display Replacement, Remove the motherboard: 7 단계, 이미지 1/3 Samsung Galaxy Watch4 Classic Display Replacement, Remove the motherboard: 7 단계, 이미지 2/3 Samsung Galaxy Watch4 Classic Display Replacement, Remove the motherboard: 7 단계, 이미지 3/3
    • Use your fingers to lift the motherboard out from the watch assembly towards the bottom of the watch.
    • During reassembly, make sure none of the flex cables become trapped underneath the motherbaord.
    • Place the corner of the flat end of a spudger in the small opening of the barometric sensor, on the opposite side of the display connector.
    • Twist and tilt the spudger to lever the core assembly out of the metal housing.
    • Thread the display flex cable through the opening in the core assembly.
    • Remove the core assembly.
  5. Samsung Galaxy Watch4 Classic Display Replacement, Heat the display: 9 단계, 이미지 1/1
    • Heat an iOpener and apply it to the display for two minutes to loosen the adhesive.
    • If your display is cracked, keep glass shards contained by applying a strip of tape over the glass.
    • Use your finger to steadily push the display down through the watch's metal housing to separate the display from the frame.
    • Remove the display.
결론
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
다른 4명이 해당 안내서를 완성하였습니다.
Adriana Zwink
회원 가입일: 12/18/19
48,699 평판
안내서 167개 작성하였습니다
iFixit iFixit 회원
Staff
136 회원들
안내서 17,392개 작성하였습니다
댓글 한 개
Where can I order the screen?
Scott Snyder - 답글
댓글 쓰기
조회 통계:
24 시간 전: 11
7일 전: 68
30일 전: 313
전체 시간: 11,076
