주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy Y Charging port and headphone jack Replacement
필요한 것
    1. Samsung Galaxy Y Charging port and headphone jack Replacement, Back Panel: 1 단계, 이미지 3개 중 1개 Samsung Galaxy Y Charging port and headphone jack Replacement, Back Panel: 1 단계, 이미지 3개 중 2개 Samsung Galaxy Y Charging port and headphone jack Replacement, Back Panel: 1 단계, 이미지 3개 중 3개
      • Use the blue plastic opening tool to pry the back-panel off of the device.
      댓글 쓰기
    1. Samsung Galaxy Y Charging port and headphone jack Replacement, Charging port and headphone jack: 2 단계, 이미지 3개 중 1개 Samsung Galaxy Y Charging port and headphone jack Replacement, Charging port and headphone jack: 2 단계, 이미지 3개 중 2개 Samsung Galaxy Y Charging port and headphone jack Replacement, Charging port and headphone jack: 2 단계, 이미지 3개 중 3개
      • Use the screwdriver with a PH000 screwdriver head to remove the four 5mm screws located in the corner of the interior back panel.
      • Remove the SD card as well by sliding the card out of it's slot.
      댓글 쓰기
    2. Samsung Galaxy Y Charging port and headphone jack Replacement: 3 단계, 이미지 3개 중 1개 Samsung Galaxy Y Charging port and headphone jack Replacement: 3 단계, 이미지 3개 중 2개 Samsung Galaxy Y Charging port and headphone jack Replacement: 3 단계, 이미지 3개 중 3개
      • Use metal pry tool to separate the interior back panel from the interior hardware and screen.
      댓글 쓰기
    3. Samsung Galaxy Y Charging port and headphone jack Replacement: 4 단계, 이미지 3개 중 1개 Samsung Galaxy Y Charging port and headphone jack Replacement: 4 단계, 이미지 3개 중 2개 Samsung Galaxy Y Charging port and headphone jack Replacement: 4 단계, 이미지 3개 중 3개
      • Disconnect the orange motherboard connection, then remove interior hardware from the front screen display.
      댓글 쓰기
    4. Samsung Galaxy Y Charging port and headphone jack Replacement: 5 단계, 이미지 3개 중 1개 Samsung Galaxy Y Charging port and headphone jack Replacement: 5 단계, 이미지 3개 중 2개 Samsung Galaxy Y Charging port and headphone jack Replacement: 5 단계, 이미지 3개 중 3개
      • Use a Phillips #000 screwdriver to remove the five 2mm screws located in the corner of the silver protective panel.
      • If the motherboard is cracked or damaged, then replace with a new one.
      댓글 쓰기
    5. Samsung Galaxy Y Charging port and headphone jack Replacement: 6 단계, 이미지 3개 중 1개 Samsung Galaxy Y Charging port and headphone jack Replacement: 6 단계, 이미지 3개 중 2개 Samsung Galaxy Y Charging port and headphone jack Replacement: 6 단계, 이미지 3개 중 3개
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Alyissa
회원 가입일: 09/21/18
133 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 12
지난 30일: 41
전체 시간: 1,314
