주요 콘텐츠로 건너뛰기
Samsung Glyde LCD Screen Replacement
필요한 것
  1. Samsung Glyde LCD Screen Replacement, Battery: 1 단계, 이미지 1/1
    • Using your thumb, press down and slide the back cover away from the camera.
  2. Samsung Glyde LCD Screen Replacement: 2 단계, 이미지 1/1
    • Remove the battery from the phone by using your plastic opening tool to find a gap at any edge of the battery and lifting the battery up.
  3. Samsung Glyde LCD Screen Replacement, Keyboard: 3 단계, 이미지 1/2 Samsung Glyde LCD Screen Replacement, Keyboard: 3 단계, 이미지 2/2
    • Use a Phillips #00 screwdriver to remove the six 4mm screws.
  4. Samsung Glyde LCD Screen Replacement: 4 단계, 이미지 1/2 Samsung Glyde LCD Screen Replacement: 4 단계, 이미지 2/2
    • Find a gap on the top side of the phone and pry apart the phone case using the plastic opening tool . Use moderate pressure to slowly maneuver around until the case is pryed apart.
    • Take the case off with your fingers
  5. Samsung Glyde LCD Screen Replacement: 5 단계, 이미지 1/2 Samsung Glyde LCD Screen Replacement: 5 단계, 이미지 2/2
    • The green film is located above the camera. It is the camera connector to the motherboard.
    • Disconnect the camera connector with the plastic opening tool.
  6. Samsung Glyde LCD Screen Replacement: 6 단계, 이미지 1/2 Samsung Glyde LCD Screen Replacement: 6 단계, 이미지 2/2
    • Take a close up of the picture for this step for a better view.
    • Use a plastic opening tool to disconnect the keyboard connector.
  7. Samsung Glyde LCD Screen Replacement: 7 단계, 이미지 1/2 Samsung Glyde LCD Screen Replacement: 7 단계, 이미지 2/2
    • The motherboard is held in place by the circular connector.
    • Using a plastic opening tool, disconnect the circular connector.
  8. Samsung Glyde LCD Screen Replacement: 8 단계, 이미지 1/3 Samsung Glyde LCD Screen Replacement: 8 단계, 이미지 2/3 Samsung Glyde LCD Screen Replacement: 8 단계, 이미지 3/3
    • A LCD connector is located underneath the motherboard.
    • Lift the far edge of the motherboard gently upwards toward the center.
    • Using a plastic opening tool, disconnect the LCD connector.
  9. Samsung Glyde LCD Screen Replacement: 9 단계, 이미지 1/2 Samsung Glyde LCD Screen Replacement: 9 단계, 이미지 2/2
    • Lift the motherboard up with your fingers.
    • Place the motherboard in a secure area.
  10. Samsung Glyde LCD Screen Replacement: 10 단계, 이미지 1/3 Samsung Glyde LCD Screen Replacement: 10 단계, 이미지 2/3 Samsung Glyde LCD Screen Replacement: 10 단계, 이미지 3/3
    • Look for the antenna which is located at the bottom end of the device. Prop the antenna out by using the plastic opening tool and slipping the tip of the tool into the edges of the antenna.
    • Using the plastic opening tool, disconnect the connector that leads from the phone to the antenna.
    • With your hands finish prying apart the antenna by lifting it up.
  11. Samsung Glyde LCD Screen Replacement: 11 단계, 이미지 1/2 Samsung Glyde LCD Screen Replacement: 11 단계, 이미지 2/2
    • The keyboard chip is located on top of the device. Pry the keyboard off of the case with the plastic opening tool.
  12. Samsung Glyde LCD Screen Replacement, LCD Screen: 12 단계, 이미지 1/2 Samsung Glyde LCD Screen Replacement, LCD Screen: 12 단계, 이미지 2/2
    • Using a #00 screwdriver, remove the 8 2mm screws connecting the display case to the sliding mechanism.
  13. Samsung Glyde LCD Screen Replacement: 13 단계, 이미지 1/2 Samsung Glyde LCD Screen Replacement: 13 단계, 이미지 2/2
    • Now remove the 5 4mm screws located under the sliding mechanism connecting the back-plate to the display.
    • You will need to maneuver the sliding mechanism around to reach all of the screws.
  14. Samsung Glyde LCD Screen Replacement: 14 단계, 이미지 1/3 Samsung Glyde LCD Screen Replacement: 14 단계, 이미지 2/3 Samsung Glyde LCD Screen Replacement: 14 단계, 이미지 3/3
    • Now it's time to desolder some components. You can gain some instruction from here.
    • Using your soldering wick and a soldering iron, desolder the contacts of the flex cable.
  15. Samsung Glyde LCD Screen Replacement: 15 단계, 이미지 1/1
    • After desoldering, verify that the gates on the two flex cables are in the "up" position and remove them.
  16. Samsung Glyde LCD Screen Replacement: 16 단계, 이미지 1/3 Samsung Glyde LCD Screen Replacement: 16 단계, 이미지 2/3 Samsung Glyde LCD Screen Replacement: 16 단계, 이미지 3/3
    • Using gentle fingers, pry the LCD screen out of its housing.
    • The flex cables connecting everything to the LCD screen are very sensitive to touch, and don't react well to pulling/tearing motions.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Cameron Law
회원 가입일: 10/12/11
142 평판
안내서 5개 작성하였습니다
Cal Poly, Team 3-12, Regan Fall 2011 Cal Poly, Team 3-12, Regan Fall 2011 회원
CPSU-REGAN-F11S3G12
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 2,207
