주요 콘텐츠로 건너뛰기
Samsung NP305E5A-A03US Battery Replacement
  1. Samsung NP305E5A-A03US Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Be sure to power down your laptop before replacing your battery.
    • Turn your laptop upside down so that the battery component is facing you.
  2. Samsung NP305E5A-A03US Battery Replacement: 2 단계, 이미지 1/1
    • Place your thumbs on the lock tabs.
    • Slide the tabs with your thumbs in an outward direction (in the direction of the arrows).
    • You should hear a click when you properly slide the tabs all the way.
  3. Samsung NP305E5A-A03US Battery Replacement: 3 단계, 이미지 1/2 Samsung NP305E5A-A03US Battery Replacement: 3 단계, 이미지 2/2
    • Pull the battery out of the laptop towards yourself to safely remove the battery.
    • If you are discarding the battery, please do not throw it away in the trash. Instead find a local battery recycling facility that will not damage the environment.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Kris Stobbe
회원 가입일: 10/30/16
585 평판
안내서 3개 작성하였습니다
Baylor, Team 5-7, Williams Fall 2016 Baylor, Team 5-7, Williams Fall 2016 회원
BU-WILLIAMS-F16S5G7
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 20
전체 시간: 543
