학생-기여 위키
자사 교육 프로그램의 멋진 학생들이 이 위키를 만들었습니다.
Device Will Not Power On
You have trouble turning on your laptop.
Faulty Battery
If your adapter is plugged in to the wall socket and the light on the adapter is on, but the laptop is not charging, then the battery might be faulty. You should replace the battery using this replacement guide.
Faulty Adapter
If your adapter is pugged in to the wall socket but the light on the adapter is not on, the adapter could be faulty. You should consider purchasing a replacement adapter if you would like to charge and turn on your laptop.
Device Runs Slow
Your Samsung NP305E5A-A03US takes longer to respond to commands.
Multiple Processes Running
If you have a hard time of letting things go which results in you having multiple windows or programs open at the same time, this could be what is slowing down your system. Shed a quick tear, and say a temporary good-bye to some of those programs by closing them down in Task Manager.
Full Hard Drive
Like a person is slow when they've been overfilled with food, your system will move slower when the hard drive is 90% full. Consider either deleting unwanted files, or upgrade your hard drive size by using replacement guide.
Low RAM
Your RAM, which stands for Random Access Memory, acts similarly to your hard drive when it's been loaded with demanding programs. Consider either closing down programs that are not being currently used, or upgrade your RAM using this replacement guide.
Unresponsive Keyboard/Keys
Your laptop has stopped responding to certain keys or the whole keyboard, or keys appear to be broken or missing.
Dirty Keyboard
If you've been eating sandwiches or any other type of food over your laptop while binge watching Gilmore Girls on Netflix and the keys won't budge any more, there may be crumbs lodged underneath the keys of your laptop. To resolve this issue, remove the keyboard cover and clean out the food residue. Once the underneath of the cover looks as if it were brand-spanking-new, simply pop it back in place.
Faulty Keyboard
If your whole keyboard is failing to respond, try restarting the laptop.
Device Overheating
Your device shows you the blue screen of death, shuts down, or freezes with no warning.
Blocked Vent
Laptops tend to overheat when there happens to be dust or other materials stuck within the vents or fan. To resolve this issue, use a can of compressed air to clean dust and stuck materials from the vents and fan.
Inefficient Fan
If the noise of your fan is continuously interrupting your Netflix time, your fan may not be the same young peppy fan it once was. Consider replacing your dear old fan with a new one by using this replacement guide.
Unresponsive CD/DVD Drive
Your new Taylor Swift CD or Finding Dory DVD is not being recognized by the laptop.
Broken/Defective CD/DVD Drive
If your Samsung NP305E5A-A03US CD/DVD drive does not open or allow you to use your newly bought CDs, the drive may be broken and will need to be replaced.
댓글 0개
