주요 콘텐츠로 건너뛰기
Samsung NP305E5A-A03US Hard Drive Replacement
필요한 것
  1. Samsung NP305E5A-A03US Hard Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Be sure to power down your laptop before replacing your battery.
    • Turn your laptop upside down so that the battery component is facing you.
  2. Samsung NP305E5A-A03US Hard Drive Replacement: 2 단계, 이미지 1/1
    • Place your thumbs on the lock tabs.
    • Slide the tabs with your thumbs in an outward direction (in the direction of the arrows).
    • You should hear a click when you properly slide the tabs all the way.
  3. Samsung NP305E5A-A03US Hard Drive Replacement: 3 단계, 이미지 1/2 Samsung NP305E5A-A03US Hard Drive Replacement: 3 단계, 이미지 2/2
    • Pull the battery out of the laptop towards yourself to safely remove the battery.
    • If you are discarding the battery, please do not throw it away in the trash. Instead find a local battery recycling facility that will not damage the environment.
  4. Samsung NP305E5A-A03US Hard Drive Replacement, Hard Drive: 4 단계, 이미지 1/1
    • Unscrew the 3.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
  5. Samsung NP305E5A-A03US Hard Drive Replacement: 5 단계, 이미지 1/1
    • Wedge the plastic opening tool between the L-shaped back panel to slide the panel off.
    • Note this may take force. If you have difficulties using the plastic opening tool, try to use your hands to pull the panel off.
  6. Samsung NP305E5A-A03US Hard Drive Replacement: 6 단계, 이미지 1/2 Samsung NP305E5A-A03US Hard Drive Replacement: 6 단계, 이미지 2/2
    • Pull the panel towards you to remove the panel.
  7. Samsung NP305E5A-A03US Hard Drive Replacement: 7 단계, 이미지 1/1
    • Unscrew the three 3.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
    • Unscrew the one 4.45mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
  8. Samsung NP305E5A-A03US Hard Drive Replacement: 8 단계, 이미지 1/2 Samsung NP305E5A-A03US Hard Drive Replacement: 8 단계, 이미지 2/2
    • Pull the cord that connects the Hard Drive to the Motherboard to disconnect it.
  9. Samsung NP305E5A-A03US Hard Drive Replacement: 9 단계, 이미지 1/1
    • Remove the Hard Drive by lifting it towards you.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Oyinda Olatundee
회원 가입일: 11/01/16
125 평판
안내서 1개 작성함
Baylor, Team 5-7, Williams Fall 2016 Baylor, Team 5-7, Williams Fall 2016 회원
BU-WILLIAMS-F16S5G7
3 회원들
안내서 5개 작성하였습니다
댓글 한 개
Necesito un hard drive model: NO305E5A-A05US
Secundino Herrera - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 24
전체 시간: 1,824
