주요 콘텐츠로 건너뛰기
Samsung NP305E5A-A03US Optical Drive Replacement
필요한 것
  1. Samsung NP305E5A-A03US Optical Drive Replacement, Hard Drive: 1 단계, 이미지 1개 중 1개
    • Unscrew the 3.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
  2. Samsung NP305E5A-A03US Optical Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Wedge the plastic opening tool between the L-shaped back panel to slide the panel off.
    • Note this may take force. If you have difficulties using the plastic opening tool, try to use your hands to pull the panel off.
  3. Samsung NP305E5A-A03US Optical Drive Replacement: 3 단계, 이미지 2개 중 1개 Samsung NP305E5A-A03US Optical Drive Replacement: 3 단계, 이미지 2개 중 2개
    • Pull the panel towards you to remove the panel.
  4. Samsung NP305E5A-A03US Optical Drive Replacement: 4 단계, 이미지 1개 중 1개
    • Unscrew the three 3.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
    • Unscrew the one 4.45mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
  5. Samsung NP305E5A-A03US Optical Drive Replacement: 5 단계, 이미지 2개 중 1개 Samsung NP305E5A-A03US Optical Drive Replacement: 5 단계, 이미지 2개 중 2개
    • Pull the cord that connects the Hard Drive to the Motherboard to disconnect it.
  6. Samsung NP305E5A-A03US Optical Drive Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the Hard Drive by lifting it towards you.
  7. Samsung NP305E5A-A03US Optical Drive Replacement, Optical Drive: 7 단계, 이미지 1개 중 1개
    • Unscrew the fourteen 9.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
    • Unscrew the two 3.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
  8. Samsung NP305E5A-A03US Optical Drive Replacement: 8 단계, 이미지 2개 중 1개 Samsung NP305E5A-A03US Optical Drive Replacement: 8 단계, 이미지 2개 중 2개
    • Insert the plastic opening tool between the seam of the back panel and the laptop.
    • Slide the plastic opening tool along the seam to loosen the back panel from the laptop.
    • It may be difficult to slide the plastic opening tool along the seam, so you may have to apply some force.
  9. Samsung NP305E5A-A03US Optical Drive Replacement: 9 단계, 이미지 3개 중 1개 Samsung NP305E5A-A03US Optical Drive Replacement: 9 단계, 이미지 3개 중 2개 Samsung NP305E5A-A03US Optical Drive Replacement: 9 단계, 이미지 3개 중 3개
    • Remove the Back Panel by lifting it towards you.
    • It may take some force to remove the Back Panel.
  10. Samsung NP305E5A-A03US Optical Drive Replacement: 10 단계, 이미지 2개 중 1개 Samsung NP305E5A-A03US Optical Drive Replacement: 10 단계, 이미지 2개 중 2개
    • Remove the Optical Drive by sliding it away from the laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Kris Stobbe
회원 가입일: 10/30/16
585 평판
안내서 3개를 작성함
Baylor, Team 5-7, Williams Fall 2016 Baylor, Team 5-7, Williams Fall 2016 회원
BU-WILLIAMS-F16S5G7
3 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 8
전체 시간: 454
