주요 콘텐츠로 건너뛰기
Samsung NX Mini LCD Replacement
필요한 것
  1. Samsung NX Mini LCD Replacement, Battery: 1 단계, 이미지 3개 중 1개 Samsung NX Mini LCD Replacement, Battery: 1 단계, 이미지 3개 중 2개 Samsung NX Mini LCD Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Orient the camera so the button panel and LCD are facing you.
    • Use a spudger or fingernail to open the battery compartment on the right side of the camera.
  2. Samsung NX Mini LCD Replacement: 2 단계, 이미지 2개 중 1개 Samsung NX Mini LCD Replacement: 2 단계, 이미지 2개 중 2개
    • Push the blue trapdoor to the left to release the battery, and remove the battery.
    • There is no battery shown in this photo.
  3. Samsung NX Mini LCD Replacement, Front Case: 3 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver to remove the 4 mm screw inside the battery compartment.
  4. Samsung NX Mini LCD Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the 4 mm Phillips #00 screw hiding in the external flash port.
  5. Samsung NX Mini LCD Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the four 5 mm Phillips #00 screws from the lens assembly.
  6. Samsung NX Mini LCD Replacement: 6 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Remove the metal lens mount by hand or with tweezers.
    • Be careful not to touch the sensor in the center of the lens assembly.
  7. Samsung NX Mini LCD Replacement: 7 단계, 이미지 1개 중 1개
    • Use tweezers to remove the inner metal ring.
  8. Samsung NX Mini LCD Replacement: 8 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver to remove the three 4 mm screws from the bottom of the case.
  9. Samsung NX Mini LCD Replacement: 9 단계, 이미지 2개 중 1개 Samsung NX Mini LCD Replacement: 9 단계, 이미지 2개 중 2개
    • Use your hands to slowly pull the front casing away from the camera.
    • The case is attached with multiple clips that may make a cracking noise as you pull it away from the camera.
  10. Samsung NX Mini LCD Replacement, Sensor: 10 단계, 이미지 3개 중 1개 Samsung NX Mini LCD Replacement, Sensor: 10 단계, 이미지 3개 중 2개 Samsung NX Mini LCD Replacement, Sensor: 10 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Gently flip the sensor cover back to expose the screw attaching the sensor cover to the ribbon cable.
    • Use a Phillips #00 screwdriver to remove the 3 mm screw from the sensor cover.
    • Use tweezers to remove the metal contact cover. Be sure to carefully remove the cover so the gold contacts remain in place.
    • The gold lens contacts lying beneath the ribbon cable become loose when the screw and contact cover are removed.
  11. Samsung NX Mini LCD Replacement: 11 단계, 이미지 2개 중 1개 Samsung NX Mini LCD Replacement: 11 단계, 이미지 2개 중 2개
    • Remove the four 4 mm Phillips #00 screws holding the sensor mount in place.
  12. Samsung NX Mini LCD Replacement: 12 단계, 이미지 3개 중 1개 Samsung NX Mini LCD Replacement: 12 단계, 이미지 3개 중 2개 Samsung NX Mini LCD Replacement: 12 단계, 이미지 3개 중 3개
    • Remove the four 4 mm Phillips #00 screws securing the battery compartment to the mother board.
    • Remove the battery compartment.
  13. Samsung NX Mini LCD Replacement: 13 단계, 이미지 2개 중 1개 Samsung NX Mini LCD Replacement: 13 단계, 이미지 2개 중 2개
    • Use a spudger to disconnect the ribbon cable connecting the image sensor to the motherboard.
  14. Samsung NX Mini LCD Replacement: 14 단계, 이미지 1개 중 1개
    • Gently remove the sensor mount from the camera case.
  15. Samsung NX Mini LCD Replacement, Flash Assembly: 15 단계, 이미지 3개 중 1개 Samsung NX Mini LCD Replacement, Flash Assembly: 15 단계, 이미지 3개 중 2개 Samsung NX Mini LCD Replacement, Flash Assembly: 15 단계, 이미지 3개 중 3개
    • Use a Phillips #00 screwdriver to remove the two 5 mm screws holding the flash assembly to the camera case.
  16. Samsung NX Mini LCD Replacement: 16 단계, 이미지 2개 중 1개 Samsung NX Mini LCD Replacement: 16 단계, 이미지 2개 중 2개
    • Remove the flash assembly by gently pulling it away from the case.
    • You may need to use a spudger to release some of the clips holding the assembly in place.
    • Avoid touching the ends of the capacitor (the large black cylinder on the right). Capacitors that haven't been discharged may cause electric shock. Learn how to discharge a capacitor here.
  17. Samsung NX Mini LCD Replacement, LCD: 17 단계, 이미지 1개 중 1개
    • Remove the 5 mm Phillips #00 screw in the top right corner of the LCD assembly.
  18. Samsung NX Mini LCD Replacement: 18 단계, 이미지 2개 중 1개 Samsung NX Mini LCD Replacement: 18 단계, 이미지 2개 중 2개
    • Tilt and wiggle the LCD to remove it from the case.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Kelsea Weber
회원 가입일: 11/12/15
21,027 평판
안내서 32개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 11
전체 시간: 681
