주요 콘텐츠로 건너뛰기
Samsung RC512 Screen Replacement
필요한 것
  1. Samsung RC512 Screen Replacement, Battery: 1 단계, 이미지 1/1
    • Place the laptop upside down.
  2. Samsung RC512 Screen Replacement: 2 단계, 이미지 1/2 Samsung RC512 Screen Replacement: 2 단계, 이미지 2/2
    • Locate two notches above the battery.
    • Slide both battery locking notches to either side to remove the battery.
    • Pull the battery out.
  3. Samsung RC512 Screen Replacement, Screen: 3 단계, 이미지 1/3 Samsung RC512 Screen Replacement, Screen: 3 단계, 이미지 2/3 Samsung RC512 Screen Replacement, Screen: 3 단계, 이미지 3/3
    • The Laptop should be off before removing the battery.
  4. Samsung RC512 Screen Replacement: 4 단계, 이미지 1/3 Samsung RC512 Screen Replacement: 4 단계, 이미지 2/3 Samsung RC512 Screen Replacement: 4 단계, 이미지 3/3
    • Remove the gray covers with tweezers to expose the 4mm screws.
    • Using a Phillips #0 screwdriver, remove the four 4 mm Phillips #0 screws.
  5. Samsung RC512 Screen Replacement: 5 단계, 이미지 1/2 Samsung RC512 Screen Replacement: 5 단계, 이미지 2/2
    • Insert the blue plastic opening tool into the bezel and rear housing of the screen.
    • Use the plastic opening tool to pop open the claps that hold the casing on the screen.
    • Work your way around the sides carefully and continue this to the bottom.
    • You may use your fingers to help remove the cover.
  6. Samsung RC512 Screen Replacement: 6 단계, 이미지 1/2 Samsung RC512 Screen Replacement: 6 단계, 이미지 2/2
    • With the Phillips #0 screwdriver remove the six 3 mm screws, which mount the screen onto the base of the laptop.
    • As you remove the last two screws, support the screen. As the screws are taken out, the screen will begin to fall forward.
  7. Samsung RC512 Screen Replacement: 7 단계, 이미지 1/3 Samsung RC512 Screen Replacement: 7 단계, 이미지 2/3 Samsung RC512 Screen Replacement: 7 단계, 이미지 3/3
    • Gently lay the LCD onto the keyboard.
    • Do not separate the LCD screen and the back panel from each other. The video connector still connects the two together.
    • Remove the tape that secures the video connector to the LCD screen with tweezers.
    • Grasp the video connector at its base and pull it away from the LCD screen.
    • The only thing holding the screen will be the clear tape causing it to come out easily.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
jando
회원 가입일: 09/15/16
896 평판
안내서 8개 작성하였습니다
USF Tampa, Team 18-2, Blackwell Fall 2016 USF Tampa, Team 18-2, Blackwell Fall 2016 회원
USFT-BLACKWELL-F16S18G2
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 696
