주요 콘텐츠로 건너뛰기
Samsung Refrigerator Evaporator Drain Clip Replacement
필요한 것
  1. Samsung Refrigerator Evaporator Drain Clip Replacement, Evaporator Drain Clip: 1 단계, 이미지 1/3 Samsung Refrigerator Evaporator Drain Clip Replacement, Evaporator Drain Clip: 1 단계, 이미지 2/3 Samsung Refrigerator Evaporator Drain Clip Replacement, Evaporator Drain Clip: 1 단계, 이미지 3/3
    • Using a spudger, pry off the cap covering the topmost screw.
  2. Samsung Refrigerator Evaporator Drain Clip Replacement: 2 단계, 이미지 1/3 Samsung Refrigerator Evaporator Drain Clip Replacement: 2 단계, 이미지 2/3 Samsung Refrigerator Evaporator Drain Clip Replacement: 2 단계, 이미지 3/3
    • Remove three 12.7 mm screws using a Phillips #0 screwdriver.
  3. Samsung Refrigerator Evaporator Drain Clip Replacement: 3 단계, 이미지 1/3 Samsung Refrigerator Evaporator Drain Clip Replacement: 3 단계, 이미지 2/3 Samsung Refrigerator Evaporator Drain Clip Replacement: 3 단계, 이미지 3/3
    • Use your hands or a spudger to pry back the plastic cover starting from the bottom.
    • Once all the clips are pulled out, loosen the cover by pushing it slightly up and out.
    • Do not pull the cover off yet; there are still connectors attaching the cover to the fridge.
  4. Samsung Refrigerator Evaporator Drain Clip Replacement: 4 단계, 이미지 1/3 Samsung Refrigerator Evaporator Drain Clip Replacement: 4 단계, 이미지 2/3 Samsung Refrigerator Evaporator Drain Clip Replacement: 4 단계, 이미지 3/3
    • Gently unplug both connectors.
    • Remember their orientations as it will be important during reassembly.
  5. Samsung Refrigerator Evaporator Drain Clip Replacement: 5 단계, 이미지 1/1
    • Using a hair dryer or heat gun, melt down any ice buildup in the draining well.
  6. Samsung Refrigerator Evaporator Drain Clip Replacement: 6 단계, 이미지 1/1
    • Cut out the old evaporating clip using a pair of cutting pliers.
  7. Samsung Refrigerator Evaporator Drain Clip Replacement: 7 단계, 이미지 1/3 Samsung Refrigerator Evaporator Drain Clip Replacement: 7 단계, 이미지 2/3 Samsung Refrigerator Evaporator Drain Clip Replacement: 7 단계, 이미지 3/3
    • Replace the old clip with a new evaporating clip.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Deep Patel
회원 가입일: 09/15/20
299 평판
안내서 1개 작성함
York University, Team S3-G60, Melo-Thaiss Fall 2020 York University, Team S3-G60, Melo-Thaiss Fall 2020 회원
YORK-MELO-THAISS-F20S3G60
1 회원
안내서 1개 작성하였습니다
댓글 3개
Problem only resolved for about 6 months post clip replacement. Now every 2 months back to defrosting my refrigerator, under the crisper drawer. Now the entire section of the drain is frozen. Very frustraing.
David Kahan - 답글
Here's another video of this replacement. Head over to the refrigerator leaking water wiki for more fixes for freezing lines.
nicO - 답글
댓글 쓰기
조회 통계:
24 시간 전: 16
7일 전: 83
30일 전: 375
전체 시간: 15,292
