주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Refrigerator Ice Bucket (Ice Tray) Replacement
필요한 것
  1. Samsung Refrigerator Ice Bucket (Ice Tray) Replacement, Open the refrigerator doors: 1 단계, 이미지 2개 중 1개 Samsung Refrigerator Ice Bucket (Ice Tray) Replacement, Open the refrigerator doors: 1 단계, 이미지 2개 중 2개
    • Open both French doors for the refrigerator compartment.
  2. Samsung Refrigerator Ice Bucket (Ice Tray) Replacement, Remove the ice bucket: 2 단계, 이미지 1개 중 1개
    • The ice bucket should be located in the upper left side of your refrigerator. It may have "Ice Master" or "Ice Max" on the outside.
  3. Samsung Refrigerator Ice Bucket (Ice Tray) Replacement, Remove the ice bucket: 3 단계, 이미지 3개 중 1개 Samsung Refrigerator Ice Bucket (Ice Tray) Replacement, Remove the ice bucket: 3 단계, 이미지 3개 중 2개 Samsung Refrigerator Ice Bucket (Ice Tray) Replacement, Remove the ice bucket: 3 단계, 이미지 3개 중 3개
  4. Samsung Refrigerator Ice Bucket (Ice Tray) Replacement, Check the ice bucket condition: 4 단계, 이미지 1개 중 1개
    • Check for cracks or fractures in the ice bucket and auger assembly. Replace the bucket as needed.
    • Check the gasket around the edge of the bucket. If the gasket's ripped, cracked, rolled or has become too rigid, the bucket won't seal properly and cause condensation to seep in and freeze.
결론
Repair didn’t go as planned? Ask our Answers Community for help.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Matt Zieminski
회원 가입일: 02/23/15
49,818 평판
안내서 28개를 작성함
testy testy 회원
Business
1 회원
안내서 164개를 작성함
4가이드 댓글
Ice dispenser cracked.. Samsung french door refrigerator...can it be fixed
Irene Motha - 답글 공유
Used Testor’s non toxic model cement after cleaning the crack with alcohol.
Mike Remote - 답글 공유
Can't get the ice bucket to line up with the auger b
Gear
Lew Pirozzi - 답글 공유
Can't get the ice bucket auger gear to line up with the motor arm.wont close.
Lew Pirozzi - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 10
지난 7일: 71
지난 30일: 372
전체 시간: 12,716
