주요 콘텐츠로 건너뛰기
Samsung Refrigerator Icemaker Auger Assembly Replacement
필요한 것
  1. Samsung Refrigerator Icemaker Auger Assembly Replacement, Unplug your refrigerator: 1 단계, 이미지 1개 중 1개
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. Samsung Refrigerator Icemaker Auger Assembly Replacement, Open the refrigerator doors: 2 단계, 이미지 2개 중 1개 Samsung Refrigerator Icemaker Auger Assembly Replacement, Open the refrigerator doors: 2 단계, 이미지 2개 중 2개
    • Open both French doors for the refrigerator compartment.
  3. Samsung Refrigerator Icemaker Auger Assembly Replacement, Remove the ice bucket: 3 단계, 이미지 1개 중 1개
    • The ice bucket should be located in the upper left side of your refrigerator. It may have "Ice Master" or "Ice Max" on the outside.
  4. Samsung Refrigerator Icemaker Auger Assembly Replacement, Remove the ice bucket: 4 단계, 이미지 3개 중 1개 Samsung Refrigerator Icemaker Auger Assembly Replacement, Remove the ice bucket: 4 단계, 이미지 3개 중 2개 Samsung Refrigerator Icemaker Auger Assembly Replacement, Remove the ice bucket: 4 단계, 이미지 3개 중 3개
  5. Samsung Refrigerator Icemaker Auger Assembly Replacement, Check the ice bucket condition: 5 단계, 이미지 1개 중 1개
    • Check for cracks or fractures in the ice bucket and auger assembly. Replace the bucket as needed.
    • Check the gasket around the edge of the bucket. If the gasket's ripped, cracked, rolled or has become too rigid, the bucket won't seal properly and cause condensation to seep in and freeze.
  6. Samsung Refrigerator Icemaker Auger Assembly Replacement, Unfasten the cable cover panel: 6 단계, 이미지 2개 중 1개 Samsung Refrigerator Icemaker Auger Assembly Replacement, Unfasten the cable cover panel: 6 단계, 이미지 2개 중 2개
    • Remove the wire harness screw securing the cable cover panel.
  7. Samsung Refrigerator Icemaker Auger Assembly Replacement, Remove the cable cover panel: 7 단계, 이미지 3개 중 1개 Samsung Refrigerator Icemaker Auger Assembly Replacement, Remove the cable cover panel: 7 단계, 이미지 3개 중 2개 Samsung Refrigerator Icemaker Auger Assembly Replacement, Remove the cable cover panel: 7 단계, 이미지 3개 중 3개
    • Use your fingers to slide the cable cover panel towards the front of the refrigerator to unlatch it.
    • Remove the cable cover panel.
    • During reassembly, make sure this panel clips fully in place, or the ice tray won't slide in properly.
  8. Samsung Refrigerator Icemaker Auger Assembly Replacement, Disconnect the icemaker harness: 8 단계, 이미지 2개 중 1개 Samsung Refrigerator Icemaker Auger Assembly Replacement, Disconnect the icemaker harness: 8 단계, 이미지 2개 중 2개
    • The exact configuration of the connectors may vary on your refrigerator.
    • Disconnect the left-most yellow connector:
    • Squeeze the locking tab with your fingers.
    • Rock the connector gently side to side to disconnect it.
    • Use your fingers or a screwdriver to guide the wire harness out of the wall clips.
  9. Samsung Refrigerator Icemaker Auger Assembly Replacement, Unfasten the air tunnel: 9 단계, 이미지 1개 중 1개
    • Remove the ice maker screw securing the air tunnel flap.
  10. Samsung Refrigerator Icemaker Auger Assembly Replacement, Remove the icemaker assembly: 10 단계, 이미지 3개 중 1개 Samsung Refrigerator Icemaker Auger Assembly Replacement, Remove the icemaker assembly: 10 단계, 이미지 3개 중 2개 Samsung Refrigerator Icemaker Auger Assembly Replacement, Remove the icemaker assembly: 10 단계, 이미지 3개 중 3개
    • A plastic clip holds the air tunnel flap in place.
    • Use a flathead screwdriver to pry and loosen the air tunnel flap from the plastic clip.
  11. Samsung Refrigerator Icemaker Auger Assembly Replacement: 11 단계, 이미지 2개 중 1개 Samsung Refrigerator Icemaker Auger Assembly Replacement: 11 단계, 이미지 2개 중 2개
    • Use your fingers to pull the air tunnel flap down enough to access the internals.
  12. Samsung Refrigerator Icemaker Auger Assembly Replacement: 12 단계, 이미지 2개 중 1개 Samsung Refrigerator Icemaker Auger Assembly Replacement: 12 단계, 이미지 2개 중 2개
    • Use a flathead screwdriver to gently pry the refrigerant loop down by 1–1.5 cm.
    • During reassembly, use your fingers to push the refrigerant loop back up.
  13. Samsung Refrigerator Icemaker Auger Assembly Replacement: 13 단계, 이미지 3개 중 1개 Samsung Refrigerator Icemaker Auger Assembly Replacement: 13 단계, 이미지 3개 중 2개 Samsung Refrigerator Icemaker Auger Assembly Replacement: 13 단계, 이미지 3개 중 3개
    • A plastic clip holds the icemaker in place.
    • Use your fingers to press and release the plastic clip.
    • This clip is stiff and may require substantial force.
  14. Samsung Refrigerator Icemaker Auger Assembly Replacement: 14 단계, 이미지 2개 중 1개 Samsung Refrigerator Icemaker Auger Assembly Replacement: 14 단계, 이미지 2개 중 2개
    • Pull the front edge of the icemaker assembly down slightly to loosen it.
    • Be careful not to bend the refrigerant loop too much as you pull the front edge, or you'll damage the loop.
    • Carefully slide the icemaker assembly out of its housing.
  15. Samsung Refrigerator Icemaker Auger Assembly Replacement, Removing the Ice Maker: 15 단계, 이미지 2개 중 1개 Samsung Refrigerator Icemaker Auger Assembly Replacement, Removing the Ice Maker: 15 단계, 이미지 2개 중 2개
  16. Samsung Refrigerator Icemaker Auger Assembly Replacement, Disconnect the auger wiring connector: 16 단계, 이미지 2개 중 1개 Samsung Refrigerator Icemaker Auger Assembly Replacement, Disconnect the auger wiring connector: 16 단계, 이미지 2개 중 2개
    • Disconnect the auger wiring connector:
    • Rock the connector side to side to loosen and disconnect it
    • Guide the wiring harness out of the retaining tabs.
    • During reassembly, make sure to re-route the wiring harness back into the retaining tabs. Otherwise, you won't be able to click the cable cover in place.
  17. Samsung Refrigerator Icemaker Auger Assembly Replacement, Remove the auger assembly: 17 단계, 이미지 3개 중 1개 Samsung Refrigerator Icemaker Auger Assembly Replacement, Remove the auger assembly: 17 단계, 이미지 3개 중 2개 Samsung Refrigerator Icemaker Auger Assembly Replacement, Remove the auger assembly: 17 단계, 이미지 3개 중 3개
    • A stiff plastic clip holds the auger assembly in place.
    • While lifting the clip with a flathead screwdriver, pull the metal head of the auger assembly to separate it from the chassis.
    • This will prevent the clip from locking back in place.
  18. Samsung Refrigerator Icemaker Auger Assembly Replacement: 18 단계, 이미지 3개 중 1개 Samsung Refrigerator Icemaker Auger Assembly Replacement: 18 단계, 이미지 3개 중 2개 Samsung Refrigerator Icemaker Auger Assembly Replacement: 18 단계, 이미지 3개 중 3개
    • Slide the auger assembly out of the refrigerator and remove it.
결론
Repair didn’t go as planned? Ask our Answers Community for help.
작성자
2다른 기여자 명과 함께
nicO
회원 가입일: 04/14/15
15,945 평판
안내서 89개를 작성함
Team Vulcan Team Vulcan 회원
Staff
6 회원들
안내서 212개를 작성함
1가이드 댓글
GOOD MORNING NICO! My Samsung Refrigerator is a unit built in about 2012. In STEP 9, you show a screw that needs removal to slide out the air tunnel. It appears that my model is a one - piece design. It does NOT have the screw. Any ideas how to proceed?
TOM
TOM PETERS - 답글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 19
지난 30일: 92
전체 시간: 2,451
