소개
Is your flash not working anymore? This guide will show you how to replace the entire flash assembly and light up your pictures.
필요한 것
Remove the 7 screws on the outside of the camera
Two 5 mm PH000 screws on the right side of the camera body
Four 3mm PH000 screws on the bottom and the left side of the camera body.
Use the plastic spundger to push the back casing out. Start from the right side and work your way clockwise around the case.
Unscrew the two 3 mm screws from the top cover with the PH000 driver.
Along with the one 2 mm screw, also a PH000 screw.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 한 개
Hola, mi camara wb2100 se queda colgada y los comandos responden pasados varios segundos y al iniciar arranca con valores por defecto, es decir que no graba las configuraciones luego que se apaga, es muy molesto usarla de esta forma y quisiera saber si hay forma de resetearla para ver si se soluciona el problema. Alguien tiene idea de como resetear esta cámara? se agradece vuestra ayuda.
