주요 콘텐츠로 건너뛰기
Sapphire Nitro+ RX 6800 XT SE Fan Replacement
필요한 것
  1. Sapphire Nitro+ RX 6800 XT SE Fan Replacement, ARGB Fans: 1 단계, 이미지 1개 중 1개
    • Unscrew the JIS000 screw securing the fan to the graphics card
  2. Sapphire Nitro+ RX 6800 XT SE Fan Replacement: 2 단계, 이미지 1개 중 1개
    • Lift the fan from the top and pull away from you.
  3. Sapphire Nitro+ RX 6800 XT SE Fan Replacement: 3 단계, 이미지 1개 중 1개
    • Clean any dust or residue present with a Q-tip damp with alcohol.
  4. Sapphire Nitro+ RX 6800 XT SE Fan Replacement: 4 단계, 이미지 1개 중 1개
    • Flip the fan over and notice the pins on the fan and in the graphics card fan slot:
    • Fan Pins
    • Fan slot
    • Flip the fan back over keeping the same orientation and carfully insert the fan.
    • If inserted incorrectly the pins could bend or break!
  5. Sapphire Nitro+ RX 6800 XT SE Fan Replacement: 5 단계, 이미지 1개 중 1개
    • Push the fan toward you to ensure that the pins are connected.
  6. Sapphire Nitro+ RX 6800 XT SE Fan Replacement: 6 단계, 이미지 1개 중 1개
    • Rescrew the JIS000 screw in the top of the fan.
    • Repeat steps 1 - 5 on the remaining fans if needed.
    • The center fan has a unique fan sicker to designate it as the middle.
결론
After assembly, the fans and RGB will work like new!
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Weston Wood
회원 가입일: 10/23/23
183 평판
안내서 1개를 작성함
댓글 2개
What is the Screw used for this? I am having trouble finding a "3mm JIS 000" screw when I look it up. I accidentally dropped the screw somewhere in the pc when taking out the fan.
Ethan Callaway - 답글
Hello, I'm trying to find the screw too! Did you find it by any chance where to get replacement?
Waleed Almutairi -
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 37
전체 시간: 816
