주요 콘텐츠로 건너뛰기
Screen Removal
단지 전제 조건
이 가이드는 전제 조건 전용 가이드입니다! 이 가이드는 다른 절차의 일부이며 단독으로 사용할 수 없습니다.
필요한 것
  1. Screen Removal, Apply tape to a cracked screen: 1 단계, 이미지 3개 중 1개 Screen Removal, Apply tape to a cracked screen: 1 단계, 이미지 3개 중 2개 Screen Removal, Apply tape to a cracked screen: 1 단계, 이미지 3개 중 3개
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
  2. Screen Removal, Heat the bottom edge: 2 단계, 이미지 1개 중 1개
    • Completely power off your device before you begin.
    • Apply a heated iOpener to the bottom edge of the device for 90 seconds to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
  3. Screen Removal, Screen removal information: 3 단계, 이미지 3개 중 1개 Screen Removal, Screen removal information: 3 단계, 이미지 3개 중 2개 Screen Removal, Screen removal information: 3 단계, 이미지 3개 중 3개
    • While you're waiting for the adhesive to loosen, note the following:
    • The areas at the top and bottom of the screen are sensitive to prying.
    • Don't insert a pick more than 3 mm to avoid damaging the screen.
    • There's a long circuit board attached to the screen that sits parallel to the left edge.
    • Don't insert a pick more than 1.5 mm to avoid damaging the circuit board.
    • The first two images are mirrored for demonstration purposes.
  4. Screen Removal, Insert an opening pick: 4 단계, 이미지 3개 중 1개 Screen Removal, Insert an opening pick: 4 단계, 이미지 3개 중 2개 Screen Removal, Insert an opening pick: 4 단계, 이미지 3개 중 3개
    • Once the screen is warm to touch, apply a suction handle to the bottom edge of the screen and as close to the edge as possible.
    • Lift the screen with the suction handle to create a small gap between the screen and the frame.
    • Insert an opening pick into the gap between the frame and the screen.
    • Don't insert the pick more than 1.5 mm to avoid damaging the circuit board.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  5. Screen Removal, Separate the bottom adhesive: 5 단계, 이미지 3개 중 1개 Screen Removal, Separate the bottom adhesive: 5 단계, 이미지 3개 중 2개 Screen Removal, Separate the bottom adhesive: 5 단계, 이미지 3개 중 3개
    • Slide the pick along the bottom edge of the device towards the bottom-right corner.
    • Leave the pick in to prevent the adhesive from resealing.
  6. Screen Removal, Heat the right edge: 6 단계, 이미지 1개 중 1개
    • Apply a heated iOpener to the right edge of the device for 90 seconds to loosen the adhesive underneath.
  7. Screen Removal, Separate the bottom-right corner adhesive: 7 단계, 이미지 3개 중 1개 Screen Removal, Separate the bottom-right corner adhesive: 7 단계, 이미지 3개 중 2개 Screen Removal, Separate the bottom-right corner adhesive: 7 단계, 이미지 3개 중 3개
    • Rotate the opening pick around the bottom-right corner of the device.
  8. Screen Removal, Separate the remaining adhesive: 8 단계, 이미지 2개 중 1개 Screen Removal, Separate the remaining adhesive: 8 단계, 이미지 2개 중 2개
    • Repeat the heating, slicing, and leaving opening picks for the remaining edges of the device.
    • When you slice near the front camera, don't insert the pick more than 1.5 mm to avoid damaging or smearing the camera.
  9. Screen Removal, Reposition the screen: 9 단계, 이미지 3개 중 1개 Screen Removal, Reposition the screen: 9 단계, 이미지 3개 중 2개 Screen Removal, Reposition the screen: 9 단계, 이미지 3개 중 3개
    • If there's still resistance around the edges of the screen, use an opening pick to cut the adhesive again.
    • Don't try to remove the screen all the way yet; it's still connected to the frame by a flex cable.
    • With the bottom of the device facing you, pull the right edge of the screen up and towards the left edge of the device.
    • Rest the screen upside down and parallel to the frame before continuing.
    • Don't twist the screen or move it too far away from the frame to avoid damaging the flex cable.
  10. Screen Removal, Unfasten the display cable bracket: 10 단계, 이미지 2개 중 1개 Screen Removal, Unfasten the display cable bracket: 10 단계, 이미지 2개 중 2개
    • Use a Phillips #000 screwdriver to remove the five 1.2 mm-long screws securing the frame bracket to the frame.
  11. Screen Removal, Remove the display cable bracket: 11 단계, 이미지 2개 중 1개 Screen Removal, Remove the display cable bracket: 11 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers, or your fingers, to remove the display cable bracket from the frame.
  12. Screen Removal, Disconnect the display: 12 단계, 이미지 3개 중 1개 Screen Removal, Disconnect the display: 12 단계, 이미지 3개 중 2개 Screen Removal, Disconnect the display: 12 단계, 이미지 3개 중 3개
    • Use the flat end of a spudger to pry up and disconnect the display cable's two press connectors secured to the frame.
  13. Screen Removal, Remove the screen: 13 단계, 이미지 2개 중 1개 Screen Removal, Remove the screen: 13 단계, 이미지 2개 중 2개
    • Remove the screen from the frame.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Alex Diaz-Kokaisl
회원 가입일: 01/16/22
214,267 평판
안내서 1,041개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,758개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 10
전체 시간: 275
