소개
If your touch screen is broken, cracked or defective, use this guide to replace a broken screen on your Samsung Galaxy A50 (SM-A505F).
For your information, the screen product codes of a Samsung Galaxy A50 are: GH82-19204A or GH82-19713A.
'Before disassembling your phone, it is advisable to discharge the battery of the Samsung Galaxy A50 below 25%.' Otherwise, if you accidentally puncture or damage the battery during repair, the battery may catch fire or explode. These risks are lessened if the battery is mostly discharged.
Note: Replacing the screen includes removing the back of the phone, which means you will need a new piece of back adhesive.
If you damage the frame, you will need to replace it, as a damaged frame could result in uneven pressure on the screen, permanently damaging or destroying it.
이 단계에 사용된 도구:Suction Handle$2.99
Heat the back of the phone for 5 minutes at 65°C
Slowly lift the back glass off the phone using a suction cup
Insert a pick into the gap created.
Slide the pick around the edge, using more picks to keep the gap open.
Disconnect the battery
Unscrew the Phillips screw holding the motherboard
Disconnect cables 1 and 2
Unplug and remove the front camera (FaceTime)
Disconnect the blue and white coaxial cables
Gently remove the motherboard by lifting it up.
Now you should have removed all the components in the phone (see picture)
Replace all the components in the new display frame according to the diagram to the right (bottom is fully assembled)
After receiving your new screen, you will need to remove the protective film from it before installing it.
To reassemble your device, follow the steps above in reverse.
Turn on your phone and test your repair before applying the new adhesive and closing the phone.
다른 16명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 6개
il me semble que le backcover du a50 est en plastique, le chauffer trop fort risque de le deformer
Getha Cruz - 답글
Done, finger print sensor won’t work any more, everything else is.
