주요 콘텐츠로 건너뛰기
Sennheiser HD 4.50 Battery Replacement
필요한 것
  1. Sennheiser HD 4.50 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Locate the side designation on the headband-earpiece junction.
    • The battery is on the left side.
    • The motherboard is on the right side.
  2. Sennheiser HD 4.50 Battery Replacement: 2 단계, 이미지 1/3 Sennheiser HD 4.50 Battery Replacement: 2 단계, 이미지 2/3 Sennheiser HD 4.50 Battery Replacement: 2 단계, 이미지 3/3
  3. Sennheiser HD 4.50 Battery Replacement: 3 단계, 이미지 1/3 Sennheiser HD 4.50 Battery Replacement: 3 단계, 이미지 2/3 Sennheiser HD 4.50 Battery Replacement: 3 단계, 이미지 3/3
    • Use a Phillips #00 screwdriver to remove the four 10 mm screws holding the ear cup cover in place.
    • Use an opening tool to pry open the cover.
    • Remove the cover.
  4. Sennheiser HD 4.50 Battery Replacement: 4 단계, 이미지 1/1
    • Use a spudger to pry the battery from the plastic case.
    • The battery is held down by a strong adhesive, so it will give resistance. You can apply a few drops of high concentration (>90%) isopropyl alcohol to the base of the battery to loosen it.
  5. Sennheiser HD 4.50 Battery Replacement: 5 단계, 이미지 1/2 Sennheiser HD 4.50 Battery Replacement: 5 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Using tweezers, pull the white battery connector upwards out of its socket.
    • Remove the battery.
    • Silicone sealant and foam tape has been used to segregate the two compartments. This will rip when the cable is removed. It can be replaced with fresh silicone if desired.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Grace Singley
회원 가입일: 02/19/21
601 평판
안내서 5개 작성하였습니다
University of Alabama, Team S2-G1, Bedsole Spring 2021 University of Alabama, Team S2-G1, Bedsole Spring 2021 회원
UA-BEDSOLE-S21S2G1
4 회원들
안내서 16개 작성하였습니다
댓글 6개
Hello ! Thanks for the tuto. Do you know where to buy the battery ?
Fren6 - 답글
You can search with the part number(Shown in the photo) : AHB622540N1/AHB622540N01.
Santanu Ghosal - 답글
Where i can find it
Erik Ridwan -
Does anyone know if I can use the he 450 bt replacement battery in a 350 bt headphone? The difference in the spec is that the 450’s battery has a longer battery life (2.2 wh vs. 1.3 wh)
M Lawson - 답글
This was pretty straightforward, but in opening the cap one of the tiny soldered wires pulled off the pad. It's so tiny that I don't have much hope of soldering it back. Any other way to reattach it? I put it back together anyways and now the right cup works fine, but the left is dead. I recommend a warning here about the little wires, if nothing else.
David Hook - 답글
댓글 쓰기
조회 통계:
24 시간 전: 20
7일 전: 143
30일 전: 584
전체 시간: 14,240
