주요 콘텐츠로 건너뛰기
Sennheiser SK100 G3 button replacement
필요한 것
  1. Sennheiser SK100 G3 button replacement, Sennheiser SK100 G3 Bodypack Transmitter button: 1 단계, 이미지 1/1
    • Turn off the transmitter and take out the batteries.
  2. Sennheiser SK100 G3 button replacement: 2 단계, 이미지 1/1
    • This is the button that's not working. All the other buttons have the same parts so if a different button is damaged, you can replace it the same way.
  3. Sennheiser SK100 G3 button replacement: 3 단계, 이미지 1/3 Sennheiser SK100 G3 button replacement: 3 단계, 이미지 2/3 Sennheiser SK100 G3 button replacement: 3 단계, 이미지 3/3
    • On the lower side of the transmitter there is a small stick holding the compartment cover.
    • Push it with your Torx Screwdriver so that the stick slides out, releasing the compartment cover.
  4. Sennheiser SK100 G3 button replacement: 4 단계, 이미지 1/1
    • Remove the 4 torx screws on the back.
  5. Sennheiser SK100 G3 button replacement: 5 단계, 이미지 1/1
    • Remove the back cover and remove one more torx screw on the upper left corner.
  6. Sennheiser SK100 G3 button replacement: 6 단계, 이미지 1/1
    • Carefully remove the front cover and locate the tactile switch that´s giving you a hard time.
  7. Sennheiser SK100 G3 button replacement: 7 단계, 이미지 1/2 Sennheiser SK100 G3 button replacement: 7 단계, 이미지 2/2
    • With a spudger o a small flat head screwdriver, carefully remove tactile switch.
    • It's not too hard to loosen up but you should do it softly.
  8. Sennheiser SK100 G3 button replacement: 8 단계, 이미지 1/2 Sennheiser SK100 G3 button replacement: 8 단계, 이미지 2/2
    • Notice the metal contacts and the direction of the tactile switchs. The small metal tab faces your right.
    • Place the new tactile switch. I didn't use glue but a tiny piece of 2mm adhesive sticker tape can work just as well.
결론
다른 17명이 해당 안내서를 완성하였습니다.
Angela Penaherrera
회원 가입일: 05/06/13
12,574 평판
안내서 5개 작성하였습니다
댓글 27개
Hi -
I just want to say thank you! I made the repair exactly as shown and put a teeny drop of rubber cement in the middle of the new tactile plate to hold it in place, happy to say it all appears to work fine. As for the part itself, the part # is the same for the G3 and you can order from them in CT, USA.
cheers,
pete
peter tooke - 답글
Cool! I'm glad the guide helped you with your repair! do you happen to have the website for the store that sells them?
^_^
Angela
Angela Penaherrera -
Yup! This works. :-)
I have the Sennheiser ew100 G3. The "down" arrow button was stuck and I couldn't change anything in my menus. What a pain!
So, I ordered two of the buttons from www.fullcompass.com this last week (item number 072512). At fullcompass, they call it a "Switch, Power SK100G2/SK100G3". It's the same button for the up arrow, down arrow, on/off and set buttons. It was $1.99 each and I ordered 2 plus $3 shipping.
I used a small screwdriver to gently pop the old button off and it actually came out in two pieces instead of one.
Anyway, I placed the new button on the little prongs and made sure it faced the same direction as the other buttons on the board. I put a little (and I mean little) piece of electrical tape over the side of the button. I'm talking like 1mm wide by 1cm long.
Screwed everything back together and voila! Working Sennheiser. Saved me almost $100 in repair. :-)
Thanks!
AngelAndres - 답글
Always happy to know of a successful repair! Good job and thanks for sharing your story ^_^
What holds the new switch on? How are the contacts made without soldering?
Charles Kaiser - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 14
30일 전: 57
전체 시간: 22,842
