주요 콘텐츠로 건너뛰기
Shark Flex DuoClean LED Headlight Replacement
필요한 것
  1. Shark Flex DuoClean LED Headlight Replacement, Garage Door: 1 단계, 이미지 1/2 Shark Flex DuoClean LED Headlight Replacement, Garage Door: 1 단계, 이미지 2/2
    • Open the garage door by sliding both of the release buttons away from you.
    • Lift off the garage door.
  2. Shark Flex DuoClean LED Headlight Replacement, Side Component: 2 단계, 이미지 1/2 Shark Flex DuoClean LED Headlight Replacement, Side Component: 2 단계, 이미지 2/2
    • Remove the plastic screw covering using a metal spudger by pushing the sharp side into the crevice and prying the cover out.
  3. Shark Flex DuoClean LED Headlight Replacement: 3 단계, 이미지 1/2 Shark Flex DuoClean LED Headlight Replacement: 3 단계, 이미지 2/2
    • Turn the T10 Security Torx screwdriver counterclockwise to remove the 15mm screw.
  4. Shark Flex DuoClean LED Headlight Replacement: 4 단계, 이미지 1/1
    • Use the iFixit Opening Tool to pry the side of the vacuum open.
  5. Shark Flex DuoClean LED Headlight Replacement: 5 단계, 이미지 1/1
    • Remove the side component with your hands.
  6. Shark Flex DuoClean LED Headlight Replacement, LED Headlight: 6 단계, 이미지 1/1
  7. Shark Flex DuoClean LED Headlight Replacement: 7 단계, 이미지 1/2 Shark Flex DuoClean LED Headlight Replacement: 7 단계, 이미지 2/2
    • Use the nylon spudger to pry the gold, plastic cover off of the headlights.
    • Prying off the cover too aggressively may cause it to break.
  8. Shark Flex DuoClean LED Headlight Replacement: 8 단계, 이미지 1/2 Shark Flex DuoClean LED Headlight Replacement: 8 단계, 이미지 2/2
  9. Shark Flex DuoClean LED Headlight Replacement: 9 단계, 이미지 1/2 Shark Flex DuoClean LED Headlight Replacement: 9 단계, 이미지 2/2
    • Use the metal spudger to pry off the clear, plastic cover on the LEDs.
    • Prying the cover off too aggressively may cause it to break.
  10. Shark Flex DuoClean LED Headlight Replacement: 10 단계, 이미지 1/1
    • Use wire cutters to detach the black cables from the LEDs on both sides.
    • Strip 1 cm off the ends of the wires, using a wire stripper.
    • Solder the exposed wires to the new LEDs.
    • Use the soldering guide in the Introduction.
결론
Samantha Mickelson
회원 가입일: 10/08/18
496 평판
안내서 4개 작성하였습니다
Cal Poly, Team S17-G5, White Fall 2018 Cal Poly, Team S17-G5, White Fall 2018 회원
CPSU-WHITE-F18S17G5
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 13
전체 시간: 1,427
