주요 콘텐츠로 건너뛰기
Shark ION RV754 Suction Motor Replacement
필요한 것
  1. Shark ION RV754 Suction Motor Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Place the unit on its back with the wheels facing up.
    • Use a Phillips #1 screwdriver to remove the single screw securing the battery compartment door.
    • Use your finger to lift off the battery door using the small indent next to it.
  2. Shark ION RV754 Suction Motor Replacement: 2 단계, 이미지 3개 중 1개 Shark ION RV754 Suction Motor Replacement: 2 단계, 이미지 3개 중 2개 Shark ION RV754 Suction Motor Replacement: 2 단계, 이미지 3개 중 3개
    • Lift the battery out just above the compartment to access the battery connector.
    • Squeeze the tab against the connector and pull it straight up to disconnect it.
    • Remove the battery completely.
  3. Shark ION RV754 Suction Motor Replacement, Wheels: 3 단계, 이미지 3개 중 1개 Shark ION RV754 Suction Motor Replacement, Wheels: 3 단계, 이미지 3개 중 2개 Shark ION RV754 Suction Motor Replacement, Wheels: 3 단계, 이미지 3개 중 3개
    • Use a TR15 Torx security screwdriver to remove five 13.85 mm screws from the left and right wheel assemblies.
  4. Shark ION RV754 Suction Motor Replacement: 4 단계, 이미지 3개 중 1개 Shark ION RV754 Suction Motor Replacement: 4 단계, 이미지 3개 중 2개 Shark ION RV754 Suction Motor Replacement: 4 단계, 이미지 3개 중 3개
    • Lift the wheel assembly out to access the cable connectors that are attached to the wheels.
    • Squeeze the tab against the connector and pull it straight out to disconnect it from the wheel.
    • Remove the wheel assembly.
    • Repeat the steps to remove the other wheel.
  5. Shark ION RV754 Suction Motor Replacement, Suction Motor: 5 단계, 이미지 1개 중 1개
    • Press the dust bin latch and slide the bin out to remove it.
  6. Shark ION RV754 Suction Motor Replacement: 6 단계, 이미지 3개 중 1개 Shark ION RV754 Suction Motor Replacement: 6 단계, 이미지 3개 중 2개 Shark ION RV754 Suction Motor Replacement: 6 단계, 이미지 3개 중 3개
    • Remove the 5 9.30 mm screws securing the bumper trim using a Torx TR8 screwdriver.
    • Use an opening tool or spudger to release the clips securing the bumper trip.
    • Carefully pull the bumper trim off the vacuum.
    • Lift the front bumper off of the vacuum.
  7. Shark ION RV754 Suction Motor Replacement: 7 단계, 이미지 3개 중 1개 Shark ION RV754 Suction Motor Replacement: 7 단계, 이미지 3개 중 2개 Shark ION RV754 Suction Motor Replacement: 7 단계, 이미지 3개 중 3개
    • Use a TR8 Torx Security screwdriver to remove the five 13.9 mm screws from the bottom of the vacuum.
    • These 13.9 mm screws are in deep recesses and the TR8 screwdriver will need an extension or a narrow shaft to reach them.
    • Remove the two 9.3 mm screws from the bottom of the vacuum near the dust bin cavity using a TR15 Torx Security screwdriver.
    • To separate the vacuum body, place one hand on the bottom and pull with the other from the brush roll recess.
  8. Shark ION RV754 Suction Motor Replacement: 8 단계, 이미지 3개 중 1개 Shark ION RV754 Suction Motor Replacement: 8 단계, 이미지 3개 중 2개 Shark ION RV754 Suction Motor Replacement: 8 단계, 이미지 3개 중 3개
    • Remove the 6 circuit board wire connectors on the left side of the board as shown.
    • Remove the 6 circuit board wire connectors on the right side of the board using the same method.
    • For helpful tips on removing the cables from the board, take a look at the Recognizing and Disconnecting Cable Connectors guide.
    • Be careful when disconnecting the wire connectors from the circuit board to avoid damage to the wires, sockets, or circuit board.
    • It is a good idea to keep a reference picture for reattaching the wires later, since many of them are very similar in color and size.
  9. Shark ION RV754 Suction Motor Replacement: 9 단계, 이미지 2개 중 1개 Shark ION RV754 Suction Motor Replacement: 9 단계, 이미지 2개 중 2개
    • Use a Phillips #1 screwdriver to remove the five 9.80 mm screws from the circuit board.
    • Gently remove the circuit board by pulling up on it as shown and set it aside.
  10. Shark ION RV754 Suction Motor Replacement: 10 단계, 이미지 3개 중 1개 Shark ION RV754 Suction Motor Replacement: 10 단계, 이미지 3개 중 2개 Shark ION RV754 Suction Motor Replacement: 10 단계, 이미지 3개 중 3개
    • Remove the three 11.6 mm screws securing the suction motor using a Phillips #1 screwdriver.
    • Disconnect the remaining wires connected to the suction motor and move the wires aside to avoid pulling on them when removing the suction motor.
    • Pull up on the suction motor to remove it.
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
작성자
1다른 기여자 명과 함께
James Holland
회원 가입일: 02/05/25
341 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 6
전체 시간: 109
