Remove the water container, the brew group and the drip tray with pomace container.
Using a spoon, remove as much of the coffee beans as possible from the coffee bean container.
Press with a flat-head screwdriver into the openings on the side with the water tank. This releases the latches on the top.
Press the flat-head screwdriver into the opening on the side with the brew group. This will release the last notch on the top.
Lift the top off.
On some models, a cable leads to the sensor on the powder tray. Unplug the connector on this cable first.
There are three latches securing the valve lid. Carefully lift the lid up using a metal spudger.
Lifting the lid exposes a spring, a plunger and its holder, an O-ring and the seal of the plunger. The photo shows clearly the imprint of the valve seat, so the valve doesn't close properly. The plunger tends to break but the spare plunger in the repair kit is made of metal.
다른 4명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
