소개
If the coffee only sprays weakly out of the two outlets, or only pours out of one of the two outlets, then they are probably blocked with coffee fat. It's difficult to properly clean the component as the aroma of the coffee will always suffer. The replacement part costs less than 4 euros, the replacement is extremely easy and will be described here.
The replacement of the coffee outlet in the Titanium line TK56001 makes more trouble, because you have to open the casing. The guide can be found here.
These instructions may also help with other Siemens/Bosch models and with coffee makers from Nivona, Melitta, and Miele—they have a very similar design.
필요한 것
To the left and right of the coffee outlet you will find two slots on the underside of the front cover.
Insert a spudger in the front edge of this slot and loosen the clips that fasten the front cover.
Pull the front cover forwards and off.
The image shows the machine after the front cover has been taken off. The four slots where the clips were are easily recognizable.
The movable coffee outlet is surrounded by a casing. Place an opening tool in the gap that separates the two halves of the casing.
Slide the tool along the gap, until the front casing becomes loose.
Remove the front casing.
다른 4명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
