주요 콘텐츠로 건너뛰기
SkullCandy INK'D 2 Audio Jack Replacement
필요한 것
  1. SkullCandy INK'D 2 Audio Jack Replacement, Audio Jack: 1 단계, 이미지 1/2 SkullCandy INK'D 2 Audio Jack Replacement, Audio Jack: 1 단계, 이미지 2/2
    • Use wire cutters to remove the audio jack.
    • Use wire cutters to remove approximately 1/2 inch of insulation of the wire and separate the four wires inside of it.
    • Red wire is the right speaker '+' terminal.
    • Green wire is the left speaker '+' terminal.
    • Golden wire is the ground terminal.
    • Purple wire is the microphone terminal.
  2. SkullCandy INK'D 2 Audio Jack Replacement: 2 단계, 이미지 1/1
    • Take the replacement connector and separate the wires on it.
    • Red wire is the right earphone.
    • Green wire is the left earphone.
    • Blue wire is the ground terminal.
    • Gold wire is the microphone.
  3. SkullCandy INK'D 2 Audio Jack Replacement: 3 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Heat Shrink Tubing Assortment
    $7.99
    구매
    • Put shrink tubing on either one of the wires.
    • For each wire color, put the headphone wire and the replacement wire into clamps. Weave them together using fingers.
    • Review the soldering guide before initiating Step 4.
  4. SkullCandy INK'D 2 Audio Jack Replacement: 4 단계, 이미지 1/1
    • Use soldering equipment to solder together two wires.
    • Repeat this step for each of the four wire colors.
    • Always wear safety glasses when soldering.
  5. SkullCandy INK'D 2 Audio Jack Replacement: 5 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Digital Multimeter
    $19.99
    구매
    • Using Digital Multimeter in the "Continuity" mode, place two probes on the soldered wires of the same color. You will hear audio signal indicating that there is a connection.
    • Repeat this for each of the wire colors.
    • If there is no Multimeter signal, you will need to resolder the wires and to make sure that wires of different colors are completely separated.
  6. SkullCandy INK'D 2 Audio Jack Replacement: 6 단계, 이미지 1/3 SkullCandy INK'D 2 Audio Jack Replacement: 6 단계, 이미지 2/3 SkullCandy INK'D 2 Audio Jack Replacement: 6 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Heat Gun
    $24.99
    구매
    • After all wires are soldered, cover them with shrink tubing.
    • Use the heat gun to shrink the tubing and fit it tightly around the wires.
    • Gently apply heat in order to shape the tubing around the soldered wires.
결론
Repeat the procedure if you need to install a new audio jack.
Maksim Bondaruk
회원 가입일: 10/16/17
119 평판
안내서 1개 작성함
Cal Poly, Team S4-G1, Livingston Fall 2017 Cal Poly, Team S4-G1, Livingston Fall 2017 회원
CPSU-LIVINGSTON-F17S4G1
5 회원들
안내서 25개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 24
30일 전: 130
전체 시간: 15,935
