주요 콘텐츠로 건너뛰기
Skullcandy Crusher Wireless Headphone USB Connector Replacement
필요한 것
  1. Skullcandy Crusher Wireless Headphone USB Connector Replacement, Ear Cushion: 1 단계, 이미지 1/2 Skullcandy Crusher Wireless Headphone USB Connector Replacement, Ear Cushion: 1 단계, 이미지 2/2
    • Take your headphones and hold them upside down for better control with your hands.
  2. Skullcandy Crusher Wireless Headphone USB Connector Replacement: 2 단계, 이미지 1/2 Skullcandy Crusher Wireless Headphone USB Connector Replacement: 2 단계, 이미지 2/2
    • Grab the ear cushion firmly between your thumb and forefinger with a tight grip.
    • Pull the ear cushion away from the plastic, covering the speaker, by sliding the ear cushion down to release it.
  3. Skullcandy Crusher Wireless Headphone USB Connector Replacement: 3 단계, 이미지 1/1
    • Continue pulling it away from the edges of the plastic covering until the cushion is fully removed.
  4. Skullcandy Crusher Wireless Headphone USB Connector Replacement, USB Connector: 4 단계, 이미지 1/2 Skullcandy Crusher Wireless Headphone USB Connector Replacement, USB Connector: 4 단계, 이미지 2/2
    • Remove three 12 mm Phillips #1 screws located underneath the left ear cushion.
  5. Skullcandy Crusher Wireless Headphone USB Connector Replacement: 5 단계, 이미지 1/3 Skullcandy Crusher Wireless Headphone USB Connector Replacement: 5 단계, 이미지 2/3 Skullcandy Crusher Wireless Headphone USB Connector Replacement: 5 단계, 이미지 3/3
    • Slide a plastic opening tool between the plastic frame and speaker assembly of the headphones.
    • Gently pry the speaker away from the frame of the headphones.
  6. Skullcandy Crusher Wireless Headphone USB Connector Replacement: 6 단계, 이미지 1/2 Skullcandy Crusher Wireless Headphone USB Connector Replacement: 6 단계, 이미지 2/2
    • Separate the headphone speaker assembly from headphone speaker frame.
  7. Skullcandy Crusher Wireless Headphone USB Connector Replacement: 7 단계, 이미지 1/1
    • Inspect the USB port and ensure that it is connected correctly. If necessary, desolder the USB port and replace it with the new port.
    • For more information on soldering, please, use this Solder and Desolder Connections guide.
결론
Val
회원 가입일: 03/31/22
1,104 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team 1-33, Gurgel Spring 2022 UMass Dartmouth, Team 1-33, Gurgel Spring 2022 회원
UMASSD-GURGEL-S22S1G33
1 회원
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 14
30일 전: 68
전체 시간: 1,069
