주요 콘텐츠로 건너뛰기
Skullcandy Hesh 3 Speaker Replacement
필요한 것
  1. Skullcandy Hesh 3 Speaker Replacement, Speaker: 1 단계, 이미지 1/3 Skullcandy Hesh 3 Speaker Replacement, Speaker: 1 단계, 이미지 2/3 Skullcandy Hesh 3 Speaker Replacement, Speaker: 1 단계, 이미지 3/3
    • Start by removing the earmuffs on the speaker side with the charging port. Gently pull from any point of the ear cushion, while also holding on to the base of the speaker.
    • Use a Phillips #00 screwdriver to remove all four 4.0 mm screws securing the faceplate.
    • Lastly, remove the faceplate by gently lifting it without pulling off the wires that are attached to the faceplate.
  2. Skullcandy Hesh 3 Speaker Replacement: 2 단계, 이미지 1/2 Skullcandy Hesh 3 Speaker Replacement: 2 단계, 이미지 2/2
    • Use a soldering iron to detach the red wire (R+) and blue wire ( R) from the motherboard.
    • The soldering iron is very hot. Be careful when using it as it can burn skin, etc. Please refer to the How to Solder and Desolder Connection guide for more information on soldering.
    • R+ should be connected to the red wire and R should be connected to the blue wire.
  3. Skullcandy Hesh 3 Speaker Replacement: 3 단계, 이미지 1/3 Skullcandy Hesh 3 Speaker Replacement: 3 단계, 이미지 2/3 Skullcandy Hesh 3 Speaker Replacement: 3 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Position the speaker so the inside is facing up.
    • Use a heat gun to warm the adhesive securing the speaker to the housing.
    • Aim the gun from a distance to prevent any damage to the plastic. Always keep the heat gun in motion while using it so one area doesn't melt.
    • Use tweezers to push the speaker through to remove it. Avoid using your hands directly on the speaker to avoid burns.
결론
Emma Lyman
회원 가입일: 01/17/23
385 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 13
전체 시간: 229
