주요 콘텐츠로 건너뛰기
Skullcandy UPROCK Earpiece Wiring Replacement
필요한 것
  1. Skullcandy UPROCK Earpiece Wiring Replacement, Earpiece Wiring: 1 단계, 이미지 1/1
    • Remove the cushion from the ear piece.
  2. Skullcandy UPROCK Earpiece Wiring Replacement: 2 단계, 이미지 1/2 Skullcandy UPROCK Earpiece Wiring Replacement: 2 단계, 이미지 2/2
    • Use a Phillips #0 to unscrew three 3.4MM screws from the earpiece.
  3. Skullcandy UPROCK Earpiece Wiring Replacement: 3 단계, 이미지 1/2 Skullcandy UPROCK Earpiece Wiring Replacement: 3 단계, 이미지 2/2
    • Find the wires connected to the speaker and check if they are intact.
  4. Skullcandy UPROCK Earpiece Wiring Replacement: 4 단계, 이미지 1/1
    • If a wire is broken, use a soldering iron to reattach it to the speaker.
    • To learn how to solder, read the How To Solder and Desolder Connections Guide.
    • After soldering is complete, the wires should look like this.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
Kayla Robinson
회원 가입일: 03/24/15
260 평판
안내서 2개 작성하였습니다
University of Alabama, Team 1-2, Naidoo Spring 2015 University of Alabama, Team 1-2, Naidoo Spring 2015 회원
UA-NAIDOO-S15S1G2
5 회원들
안내서 4개 작성하였습니다
댓글 한 개
my jack is broken can i get a whole new wire so i could do soldering or can i use any other wire. if i use any other wire can i connect in btw of old wire coz i removed the jack by cutting the wire from jack or do i have to do soldering from beginning form inside.
Anuj Verma - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 9
전체 시간: 6,196
