주요 콘텐츠로 건너뛰기
Skytex Skypad Alpha 2 Antenna Replacement
필요한 것
  1. Skytex Skypad Alpha 2 Antenna Replacement, Back Cover: 1 단계, 이미지 1/1
    • Power off the tablet.
    • Unplug the tablet from the power source if it is connected.
  2. Skytex Skypad Alpha 2 Antenna Replacement: 2 단계, 이미지 1/2 Skytex Skypad Alpha 2 Antenna Replacement: 2 단계, 이미지 2/2
    • Remove the (4) 3.5mm screws using a phillips #000 screwdriver.
  3. Skytex Skypad Alpha 2 Antenna Replacement: 3 단계, 이미지 1/1
    • Use the plastic opening tool to work your way around the tablet, releasing the back case from the tabs.
  4. Skytex Skypad Alpha 2 Antenna Replacement: 4 단계, 이미지 1/1
    • Release the back case from the rest of the tablet with your hand.
    • Do not pry the case too hard; doing so can damage the tablet.
  5. Skytex Skypad Alpha 2 Antenna Replacement, Antenna: 5 단계, 이미지 1/1
    • Remove the metallic electrical tape, just enough, to allow the antenna to hang freely.
    • Remove all black and yellow tape, if necessary, on the motherboard.
  6. Skytex Skypad Alpha 2 Antenna Replacement: 6 단계, 이미지 1/1
    • Remove the soldered connections to separate the antenna wire from the motherboard.
    • The antenna wire will be connected to the motherboard with 2 connections, so be sure to remove both with the soldering iron.
    • Follow the link below for further soldering information: How To Solder and Desolder Connections.
    • Soldering irons require a large amount of heat; use caution when performing this step. Excessive heat can damage parts of your device; do not leave the soldering iron on connections for extended periods of time.
  7. Skytex Skypad Alpha 2 Antenna Replacement: 7 단계, 이미지 1/1
    • Remove the antenna from the tablet using a pair of tweezers.
    • The antenna is actually fastened inside the back case of the tablet, pull gently to free it from the adhesive.
결론
Rebecca Ramirez
회원 가입일: 09/23/15
481 평판
안내서 3개 작성하였습니다
Baylor, Team 6-5, Williams Fall 2015 Baylor, Team 6-5, Williams Fall 2015 회원
BU-WILLIAMS-F15S6G5
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 139
