주요 콘텐츠로 건너뛰기
Skytex Skypad Alpha 2 Battery Replacement
필요한 것
  1. Skytex Skypad Alpha 2 Battery Replacement, Back Cover: 1 단계, 이미지 1/1
    • Power off the tablet.
    • Unplug the tablet from the power source if it is connected.
  2. Skytex Skypad Alpha 2 Battery Replacement: 2 단계, 이미지 1/2 Skytex Skypad Alpha 2 Battery Replacement: 2 단계, 이미지 2/2
    • Remove the (4) 3.5mm screws using a phillips #000 screwdriver.
  3. Skytex Skypad Alpha 2 Battery Replacement: 3 단계, 이미지 1/1
    • Use the plastic opening tool to work your way around the tablet, releasing the back case from the tabs.
  4. Skytex Skypad Alpha 2 Battery Replacement: 4 단계, 이미지 1/1
    • Release the back case from the rest of the tablet with your hand.
    • Do not pry the case too hard; doing so can damage the tablet.
  5. Skytex Skypad Alpha 2 Battery Replacement, Battery: 5 단계, 이미지 1/1
    • Remove soldered connections to separate the battery wires from the motherboard.
    • Remove all black and yellow tape, if necessary, on motherboard.
    • Following the red and black wires, that come out of the battery, to their respective connections on the motherboard will indicate where to solder.
    • Follow link for further soldering information: How to Solder and Desolder Connections
  6. Skytex Skypad Alpha 2 Battery Replacement: 6 단계, 이미지 1/1
    • Use the plastic opening tool to remove battery from tablet.
    • Be sure to remove the battery carefully to avoid damage. Damage of battery can release harmful chemicals and may cause a fire.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Rebecca Ramirez
회원 가입일: 09/23/15
481 평판
안내서 3개 작성하였습니다
Baylor, Team 6-5, Williams Fall 2015 Baylor, Team 6-5, Williams Fall 2015 회원
BU-WILLIAMS-F15S6G5
3 회원들
안내서 8개 작성하였습니다
댓글 한 개
Excellent Guide
Problem is where to obtain the Replacement battery ???
J P SULLIVAN - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 8
전체 시간: 789
