주요 콘텐츠로 건너뛰기
Slider of toaster does not stay down - Repair
필요한 것
  1. Slider of toaster does not stay down - Repair, Slider of toaster does not stay down: 1 단계, 이미지 2개 중 1개 Slider of toaster does not stay down - Repair, Slider of toaster does not stay down: 1 단계, 이미지 2개 중 2개
    • The repair is done on an old Tefal model 539627, but is the same for many toasters.
    • Never forget the first step: pull the plug!
  2. Slider of toaster does not stay down - Repair: 2 단계, 이미지 2개 중 1개 Slider of toaster does not stay down - Repair: 2 단계, 이미지 2개 중 2개
    • Pull off the button on the slider, you need a lot of strength to do this.
  3. Slider of toaster does not stay down - Repair: 3 단계, 이미지 2개 중 1개 Slider of toaster does not stay down - Repair: 3 단계, 이미지 2개 중 2개
    • Also pull off the knob on the controller, a lever tool was used here.
  4. Slider of toaster does not stay down - Repair: 4 단계, 이미지 1개 중 1개
    • Place the toaster face down on the work surface.
    • Pull out the crumb drawer.
  5. Slider of toaster does not stay down - Repair: 5 단계, 이미지 2개 중 1개 Slider of toaster does not stay down - Repair: 5 단계, 이미지 2개 중 2개
    • The upper part is fixed by five Phillips screws to the lower part. Find the screws sitting in deep holes.
    • Three of the screws are in the front half.
    • Two of the screws are in the other half under the crumb drawer.
    • Unscrew and remove all screws.
  6. Slider of toaster does not stay down - Repair: 6 단계, 이미지 1개 중 1개
    • Insert a plastic tool into the seam between the upper and lower part and enlarge the gap all around.
    • Pull the top off the bottom, paying attention to the axes of the controller and the slider.
    • This may require some force.
    • Lift the top off and put it aside.
  7. Slider of toaster does not stay down - Repair: 7 단계, 이미지 2개 중 1개 Slider of toaster does not stay down - Repair: 7 단계, 이미지 2개 중 2개
    • Here are the main internal parts:
    • The contacts for the heating wires. They are switched when the slider moves down
    • The timer. The longer the time, the darker the toast.
    • The holding magnet, it's here where you have to look for the solution.
  8. Slider of toaster does not stay down - Repair: 8 단계, 이미지 2개 중 1개 Slider of toaster does not stay down - Repair: 8 단계, 이미지 2개 중 2개
    • There is an iron tilting device on the magnet, here embedded in a molded plastic part. When the magnet pulls in, it holds the hook on the slide.
    • Thoroughly clean the space between the magnet and the iron holder. Use a cotton swab with alcohol.
  9. Slider of toaster does not stay down - Repair: 9 단계, 이미지 1개 중 1개
    • Caution mains voltage: do not touch conductive parts!
    • Insert the power plug and test whether your repair was successful.
    • Pull the power plug again and clean the toaster thoroughly before assembling
결론
To reassemble your toaster, follow these instructions in reverse order.
다른 16명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
de en
100%
이 번역인들은 저희가 세상을 수리하는 데 도움을 주고 있어요! 기여하시겠습니까?
번역 시작하기 ›
작성자
3다른 기여자 명과 함께
VauWeh
회원 가입일: 10/19/15
299,149 평판
안내서 303개를 작성함
12가이드 댓글
Hey super, das klappte!!
rauh.georg - 답글
Mein Toaster sieht leider anders innen.. schade, das hat nicht geklappt.
Elke Kratzer - 답글
Hallo Elke,
es gibt neben den Toastern mit dem Magneten noch eine andere, weit verbreitete Toaster-Bauart, bei dem ein kleiner Haken aus Kunststoff oder Metall den Auswurf solange unten hält, bis ein Bimetall sich entspechend erwärmt oder eine Zeitschaltuhr auslöst. Häufig greifen diese kleinen Haken nicht mehr, und der Auswurf rutscht immer nach oben. Hier hilft in der Regel eine kleine Dreikantfeile oder die Rekonstruktion des Hakens.
Bei einigen Fällen ist aber auch der “Zeitgeber” defekt.
Michael - 답글
Danke für die Tipps, sie konnten problemlos auf meinen Severin Toaster übertragen werden. Hat wunderbar geklappt.
Peter F.
28.1.22
Peter F. - 답글
Hat leider nicht funktioniert! Toaster der Marke Koenic KTO 120 elektr. HALTEMAGNET defekt. Konnte einfach ohne Abdeckung ( ACHTUNG AUF STROMFÜHRENDE TEILE ) getestet werden = Magnet ohne Funktion !!,
Das Gerät ist noch keine sechs Monate alt… , Definitiv keine Kaufempfehlung!
Quattrose - 답글
댓글 쓰기
조회 통계:
지난 24시간: 45
지난 7일: 332
지난 30일: 1,585
전체 시간: 114,759
