주요 콘텐츠로 건너뛰기
Slingbox SOLO DC Power Connector Replacement
필요한 것
  1. Slingbox SOLO DC Power Connector Replacement, Motherboard: 1 단계, 이미지 1/1
    • Use the plastic opening tool to remove the four rubber pads from the bottom of the device.
  2. Slingbox SOLO DC Power Connector Replacement: 2 단계, 이미지 1/3 Slingbox SOLO DC Power Connector Replacement: 2 단계, 이미지 2/3 Slingbox SOLO DC Power Connector Replacement: 2 단계, 이미지 3/3
    • The Slingbox has four black 5mm screws, one on each corner of the case.
    • Remove the four black 5mm screws using the PH1 screwdriver.
    • Gently pull and separate the two case covers.
  3. Slingbox SOLO DC Power Connector Replacement: 3 단계, 이미지 1/3 Slingbox SOLO DC Power Connector Replacement: 3 단계, 이미지 2/3 Slingbox SOLO DC Power Connector Replacement: 3 단계, 이미지 3/3
    • The motherboard has five silver 5.5mm screws connecting it to the base of the Slingbox.
    • Remove the five silver screws on the motherboard using the PH1 screwdriver.
    • Gently slide and separate the motherboard from the base.
  4. Slingbox SOLO DC Power Connector Replacement, DC Power Connector: 4 단계, 이미지 1/1
    • Do not touch the heated tip of the soldering iron.
    • Check this guide out to learn how to use a soldering iron.
    • Desolder all three lead prongs.
    • Gently pull the DC power connector from the motherboard.
결론
To reassemble your device, follow the instructions in reverse order.
Nitin Muralidhar
회원 가입일: 07/18/16
222 평판
안내서 2개 작성하였습니다
IUPUI, Team 2-2, Harley SU 2016 IUPUI, Team 2-2, Harley SU 2016 회원
IUPUI-HARLEY-SU16S2G2
5 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 10
전체 시간: 288
