주요 콘텐츠로 건너뛰기
Solio Rocsta Charging Cable Replacement
필요한 것
  1. Solio Rocsta Charging Cable Replacement, Charging Cable: 1 단계, 이미지 1/2 Solio Rocsta Charging Cable Replacement, Charging Cable: 1 단계, 이미지 2/2
    • Locate, and unscrew, the three 5.72 mm screws that hold down the top cover using the T6 Torx screwdriver.
  2. Solio Rocsta Charging Cable Replacement: 2 단계, 이미지 1/2 Solio Rocsta Charging Cable Replacement: 2 단계, 이미지 2/2
    • Remove top cover.
    • Caution: the solar cell is attached to the top cover and connected to the circuit board by a short wire.
  3. Solio Rocsta Charging Cable Replacement: 3 단계, 이미지 1/1
    • Using the spudger, pry the battery off the back cover.
  4. Solio Rocsta Charging Cable Replacement: 4 단계, 이미지 1/1
    • Unscrew the 5.66 mm screws attaching the circuit board to the case.
  5. Solio Rocsta Charging Cable Replacement: 5 단계, 이미지 1/1
    • With the circuit board flipped, locate the battery connector.
    • Hold the component attached to the circuit board the battery is connected to and wiggle the cable out.
  6. Solio Rocsta Charging Cable Replacement: 6 단계, 이미지 1/1
    • With a Soldering Iron, desolder the four cables that connect the charging cable to the circuit board.
    • The power cable is a series of four cables. Make note of each cable placement for easy resoldering.
    • For more information on how to solder and desolder connections, please visit this guide.
결론
David Vazquez
회원 가입일: 10/10/17
577 평판
안내서 5개 작성하였습니다
USF Tampa, Team S13-G13, Cagle Fall 2017 USF Tampa, Team S13-G13, Cagle Fall 2017 회원
USFT-CAGLE-F17S13G13
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 13
전체 시간: 194
