주요 콘텐츠로 건너뛰기
Solio Rocsta Charging Indicator Button Replacement
필요한 것
  1. Solio Rocsta Charging Indicator Button Replacement, Solio Rocsta Top Cover Disassembly: 1 단계, 이미지 2개 중 1개 Solio Rocsta Charging Indicator Button Replacement, Solio Rocsta Top Cover Disassembly: 1 단계, 이미지 2개 중 2개
    • Locate, and unscrew, the three 5.72 mm screws that hold down the top cover using the T6 Torx screwdriver.
  2. Solio Rocsta Charging Indicator Button Replacement: 2 단계, 이미지 2개 중 1개 Solio Rocsta Charging Indicator Button Replacement: 2 단계, 이미지 2개 중 2개
    • Remove top cover.
    • Caution: the solar cell is attached to the top cover and connected to the circuit board by a short wire .
  3. Solio Rocsta Charging Indicator Button Replacement, Battery: 3 단계, 이미지 1개 중 1개
    • Using the spudger, pry the battery off the back cover.
  4. Solio Rocsta Charging Indicator Button Replacement: 4 단계, 이미지 1개 중 1개
    • Using a T6 Torx screwdriver, unscrew the 5.66 mm screws attaching the circuit board to the case and flip the circuit board.
  5. Solio Rocsta Charging Indicator Button Replacement: 5 단계, 이미지 1개 중 1개
    • With the circuit board flipped, locate the battery connector.
    • Hold the component attached to the circuit board the battery is connected to and wiggle the cable out.
  6. Solio Rocsta Charging Indicator Button Replacement, Charging Indicator Button: 6 단계, 이미지 1개 중 1개
    • Unscrew the 5.66 mm screws attaching the circuit board to the case.
  7. Solio Rocsta Charging Indicator Button Replacement: 7 단계, 이미지 1개 중 1개
    • With a Soldering Iron desolder the charging indicator button connectors.
    • For more information on how to solder and desolder connections, please visit this guide.
  8. Solio Rocsta Charging Indicator Button Replacement: 8 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Gently pry the charging indicator button using one of the Precision Tweezers.
결론
작성자
3다른 기여자 명과 함께
David Vazquez
회원 가입일: 10/10/17
577 평판
안내서 5개를 작성함
USF Tampa, Team S13-G13, Cagle Fall 2017 USF Tampa, Team S13-G13, Cagle Fall 2017 회원
USFT-CAGLE-F17S13G13
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 12
전체 시간: 187
