주요 콘텐츠로 건너뛰기
Sony α6000 Lens Assembly Replacement
필요한 것
  1. Sony α6000 Lens Assembly Replacement, Battery: 1 단계, 이미지 1/2 Sony α6000 Lens Assembly Replacement, Battery: 1 단계, 이미지 2/2
    • Begin by placing the camera facing upside down.
  2. Sony α6000 Lens Assembly Replacement: 2 단계, 이미지 1/2 Sony α6000 Lens Assembly Replacement: 2 단계, 이미지 2/2
    • Slide the notched locking bar on the battery compartment from LOCK to OPEN.
  3. Sony α6000 Lens Assembly Replacement: 3 단계, 이미지 1/2 Sony α6000 Lens Assembly Replacement: 3 단계, 이미지 2/2
    • Push the small blue bar horizontally off of the battery.
  4. Sony α6000 Lens Assembly Replacement: 4 단계, 이미지 1/2 Sony α6000 Lens Assembly Replacement: 4 단계, 이미지 2/2
    • Remove the battery.
  5. Sony α6000 Lens Assembly Replacement, Lens Assembly: 5 단계, 이미지 1/1
    • Place the camera with the lens facing upwards.
    • Remove the four 1.75 mm Phillips #00 screws from the front face of the camera.
  6. Sony α6000 Lens Assembly Replacement: 6 단계, 이미지 1/1
    • Carefully remove the outer most silver ring from the lens assembly.
  7. Sony α6000 Lens Assembly Replacement: 7 단계, 이미지 1/1
    • Carefully remove the black ring from the lens assembly.
  8. Sony α6000 Lens Assembly Replacement: 8 단계, 이미지 1/1
    • Carefully remove the thin silver ring from the lens assembly.
결론
다른 2명이 해당 안내서를 완성하였습니다.
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 25
전체 시간: 644
