주요 콘텐츠로 건너뛰기
Sony Alpha 5100 LCD Replacement
필요한 것
  1. Sony Alpha 5100 LCD Replacement, LCD: 1 단계, 이미지 1/1
    • Slide the power switch on the top of the camera to "off."
  2. Sony Alpha 5100 LCD Replacement: 2 단계, 이미지 1/1
    • Flip the LCD screen so that you have access to the back of the screen. The front of the screen should be facing the direction that the lens is facing.
  3. Sony Alpha 5100 LCD Replacement: 3 단계, 이미지 1/2 Sony Alpha 5100 LCD Replacement: 3 단계, 이미지 2/2
    • Remove the two 2mm Phillips #00 screws on the back of the screen.
    • Remove the two 2mm Phillips #00 screws on the top of the LCD screen.
  4. Sony Alpha 5100 LCD Replacement: 4 단계, 이미지 1/1
    • Carefully pry open the back plate off the screen with an iFixit opening tool.
    • If separating the plates is giving you trouble, aim for the notch at the bottom of the plate.
  5. Sony Alpha 5100 LCD Replacement: 5 단계, 이미지 1/2 Sony Alpha 5100 LCD Replacement: 5 단계, 이미지 2/2
    • Carefully open the back plate of the screen.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Kevin Raggiani
회원 가입일: 10/30/19
444 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team S4-G6, Saloman Fall 2019 UMass Dartmouth, Team S4-G6, Saloman Fall 2019 회원
UMASSD-SALOMAN-F19S4G6
3 회원들
안내서 8개 작성하였습니다
댓글 한 개
Hello, thank you for this but it’s only half the steps, how to remove the LCD and touch screen after step 5? Something else is holding it in place. Can lift the outer edge a little only. Possibly it is glue or tape? My touchscreen is always active and focus rectangle moving around the lower part of screen. Can touch screen and it will go there but soon moves back to lower area.
Thank you.
John Meldrum - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 39
전체 시간: 1,669
