주요 콘텐츠로 건너뛰기
Sony BDP-S1 RC Socket Replacement
필요한 것
  1. Sony BDP-S1 RC Socket Replacement, Sony BDP-S1: Getting inside the device: 1 단계, 이미지 1/2 Sony BDP-S1 RC Socket Replacement, Sony BDP-S1: Getting inside the device: 1 단계, 이미지 2/2
    • Remove the 12mm screws with the Philips #2 screwdriver which keep the plastic panels in place.
    • Don't forget, there are two more 12mm screws on the other side as well.
  2. Sony BDP-S1 RC Socket Replacement: 2 단계, 이미지 1/3 Sony BDP-S1 RC Socket Replacement: 2 단계, 이미지 2/3 Sony BDP-S1 RC Socket Replacement: 2 단계, 이미지 3/3
    • First, remove the three 12mm black screws holding the top panel on (Phillips #2).
    • Then, remove the two 12mm black screws - one on each side of the back of the device - holding the top panel on.
    • Lastly, remove the three 12mm black screws on each side of device.
  3. Sony BDP-S1 RC Socket Replacement: 3 단계, 이미지 1/3 Sony BDP-S1 RC Socket Replacement: 3 단계, 이미지 2/3 Sony BDP-S1 RC Socket Replacement: 3 단계, 이미지 3/3
    • Carefully lift up the top panel, because there are two blue ribbon cables that must be disconnected before removing the panel, and we do NOT want them to break.
    • After gently disconnecting the two ribbon cables (you can just pull them out with your hand), take the top off and set it to the side.
  4. Sony BDP-S1 RC Socket Replacement: 4 단계, 이미지 1/3 Sony BDP-S1 RC Socket Replacement: 4 단계, 이미지 2/3 Sony BDP-S1 RC Socket Replacement: 4 단계, 이미지 3/3
    • After the top is off, you'll see that there are two metal bars that go across the top of the device.
    • Remove each bar by unscrewing the two 10mm silver screws on each end.
  5. Sony BDP-S1 RC Socket Replacement, RC Socket: 5 단계, 이미지 1/3 Sony BDP-S1 RC Socket Replacement, RC Socket: 5 단계, 이미지 2/3 Sony BDP-S1 RC Socket Replacement, RC Socket: 5 단계, 이미지 3/3
    • These are the RC sockets. They are the audio output that sends a signal set of speakers.
    • Unscrew the frame to access the circuit board.
    • Remove the four screws circled in the figure using a Phillips #2 Screwdriver.
  6. Sony BDP-S1 RC Socket Replacement: 6 단계, 이미지 1/2 Sony BDP-S1 RC Socket Replacement: 6 단계, 이미지 2/2
    • White arrows point to the screws that are required for removal.
    • Remove the three screws circled in orange with a Phillips #2 Screwdriver.
    • Remove the three screws opposite to the orange screws with a Phillips #2 Screwdriver.
  7. Sony BDP-S1 RC Socket Replacement: 7 단계, 이미지 1/3 Sony BDP-S1 RC Socket Replacement: 7 단계, 이미지 2/3 Sony BDP-S1 RC Socket Replacement: 7 단계, 이미지 3/3
    • Remove the cable ribbon that is attached to the motherboard.
    • And voila! You have successfully taken out the circuit board.
    • And here we see the solder that keeps the RC components strapped into the board. In order to get them off and put them back on, you'll need a soldering iron, wick, and solder itself.
    • If you don't know how to solder properly, there are plenty of helpful guides online, such as this one. Make sure to remove the solder all the way before removing the RC jacks, otherwise you could hurt the board.
    • Now you just have to take off the RC components, place the news ones in, and solder them into the board (again using a soldering guide if you need to).
    • Good work! Now celebrate by listening to your favorite movie!
결론
When reassembling your device, solder in any RC components needed and then follow these instructions in reverse order.
첨부 문서
Jaden Laidig
회원 가입일: 01/26/14
560 평판
안내서 2개 작성하였습니다
Cal Poly, Team 12-3, Green Winter 2015 Cal Poly, Team 12-3, Green Winter 2015 회원
CPSU-GREEN-W15S12G3
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 9
전체 시간: 622
