소개
This is a guide to remove the front panel assembly of the Sony BDP S3500.
Be sure to review the troubleshooting guide, as most of the time the problems are due malfunctioning software rather than it being a hardware issue.
This guide will show you how to safely remove the front panel assembly without damaging the other components.
필요한 것
Use the Phillips #2 screwdriver to remove the two 9mm screws located on the back of the device.
다른 2명이 해당 안내서를 완성하였습니다.
