주요 콘텐츠로 건너뛰기
Sony BDP-S3500 Port Board Replacement
필요한 것
  1. Sony BDP-S3500 Port Board Replacement, Front Panel: 1 단계, 이미지 1/2 Sony BDP-S3500 Port Board Replacement, Front Panel: 1 단계, 이미지 2/2
    • Use the Phillips #2 screwdriver to remove the two 9mm screws located on the back of the device.
  2. Sony BDP-S3500 Port Board Replacement: 2 단계, 이미지 1/1
    • Slide the top panel off towards the back of the device.
    • Remove the top panel.
  3. Sony BDP-S3500 Port Board Replacement: 3 단계, 이미지 1/2 Sony BDP-S3500 Port Board Replacement: 3 단계, 이미지 2/2
    • Unclip the plastic tags from the bottom of the device.
    • Unclip the plastic tags from the sides of the device.
    • Slide the front panel off.
  4. Sony BDP-S3500 Port Board Replacement, Port Board: 4 단계, 이미지 1/2 Sony BDP-S3500 Port Board Replacement, Port Board: 4 단계, 이미지 2/2
    • Keep the back side up and facing towards you.
    • Carefully disconnect the blue ribbon connecting the port board and motherboard.
    • Be delicate while removing the ribbon.
  5. Sony BDP-S3500 Port Board Replacement: 5 단계, 이미지 1/1
    • Use a Phillips #2 screwdriver to remove the 9mm screw from the port board.
  6. Sony BDP-S3500 Port Board Replacement: 6 단계, 이미지 1/1
    • Remove the port board from the device.
결론
Megh Ladumor
회원 가입일: 01/22/20
100 평판
안내서 1개 작성함
York University, Team S8-G4, Turner Winter 2020 York University, Team S8-G4, Turner Winter 2020 회원
YORK-TURNER-W20S8G4
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 9
전체 시간: 282
