주요 콘텐츠로 건너뛰기
Sony BDP-s7200 Motherboard Replacement
필요한 것
  1. Sony BDP-s7200  Motherboard Replacement, Back Cover: 1 단계, 이미지 1/1
    • Remove the disk tray cover from the device.
  2. Sony BDP-s7200  Motherboard Replacement: 2 단계, 이미지 1/2 Sony BDP-s7200  Motherboard Replacement: 2 단계, 이미지 2/2
    • Using the Phillips #2 Screwdriver, remove the five 9mm from the bottom of the device.
    • Remove the metal cover.
  3. Sony BDP-s7200  Motherboard Replacement: 3 단계, 이미지 1/2 Sony BDP-s7200  Motherboard Replacement: 3 단계, 이미지 2/2
    • Using the Phillips #2 Screwdriver, remove the six 9mm screws from the back of the device.
  4. Sony BDP-s7200  Motherboard Replacement: 4 단계, 이미지 1/1
    • Pull off the back panel and remove it from the device.
  5. Sony BDP-s7200  Motherboard Replacement, Front Panel Cover: 5 단계, 이미지 1/3 Sony BDP-s7200  Motherboard Replacement, Front Panel Cover: 5 단계, 이미지 2/3 Sony BDP-s7200  Motherboard Replacement, Front Panel Cover: 5 단계, 이미지 3/3
    • Using the plastic opening tool, open one of the tabs on the bottom of the device.
    • While keeping the tab open, insert a opening pick in between the opening tool and tab.
    • Repeat this for the 3 other tabs.
  6. Sony BDP-s7200  Motherboard Replacement: 6 단계, 이미지 1/2 Sony BDP-s7200  Motherboard Replacement: 6 단계, 이미지 2/2
    • Place your hands on the two black circles on the bottom of the device.
    • Pull on the black circles to remove the device from its front panel cover.
  7. Sony BDP-s7200  Motherboard Replacement: 7 단계, 이미지 1/3 Sony BDP-s7200  Motherboard Replacement: 7 단계, 이미지 2/3 Sony BDP-s7200  Motherboard Replacement: 7 단계, 이미지 3/3
    • Using the Phillips #2 Screwdriver, remove the seven 9mm screws from the top of the device.
    • Using the same screwdriver, remove the three 9mm screws from the back of the device.
    • Using the same screwdriver, remove the one 9mm screw still connecting the small metal clip to the front of the device.
  8. Sony BDP-s7200  Motherboard Replacement: 8 단계, 이미지 1/2 Sony BDP-s7200  Motherboard Replacement: 8 단계, 이미지 2/2
    • Remove the small metal clip on the front of the device.
    • Remove the metal cover on the top of the device.
  9. Sony BDP-s7200  Motherboard Replacement, Motherboard: 9 단계, 이미지 1/2 Sony BDP-s7200  Motherboard Replacement, Motherboard: 9 단계, 이미지 2/2
    • Remove the ribbon cables connected to the front panel board.
    • Pull firmly, but not too hard as to not damage the ribbon cable.
  10. Sony BDP-s7200  Motherboard Replacement: 10 단계, 이미지 1/1
    • Remove the cable connected to the power supply.
  11. Sony BDP-s7200  Motherboard Replacement: 11 단계, 이미지 1/1
    • Remove the ribbon cables that connect the motherboard to the disk drive.
    • Pull firmly, but not too hard as to not damage the ribbon cables.
  12. Sony BDP-s7200  Motherboard Replacement: 12 단계, 이미지 1/3 Sony BDP-s7200  Motherboard Replacement: 12 단계, 이미지 2/3 Sony BDP-s7200  Motherboard Replacement: 12 단계, 이미지 3/3
    • Remove the three screws using the Phillips #2 Screwdriver.
    • Do not attempt to remove. There is one additional screw on the back of the device.
    • Remove the screw on the back of the device with the same screwdriver.
  13. Sony BDP-s7200  Motherboard Replacement: 13 단계, 이미지 1/2 Sony BDP-s7200  Motherboard Replacement: 13 단계, 이미지 2/2
    • Lift the motherboard from the front and carefully pull it out.
    • There is a small square adhesive on the bottom. Leave it there for reassembly.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Erik Preston
회원 가입일: 01/16/20
412 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 5
30일 전: 8
전체 시간: 396
