소개
If any of the ports on the back of your blu-ray player are broken, or not working, you may need to replace the motherboard entirely, as that is what they are connected to.
The motherboard is the brains of the blu-ray player, and without it, the blu-ray player won’t be able to do anything. It also connects together many of the other components of the device, which can lead to it often being the place where an issue occurs. However, it is still possible that the error could be due to something other than the motherboard. We recommend reviewing the troubleshooting guide for this device beforehand, just to confirm that it is the motherboard.
This guide will demonstrate how quick and easy it is to replace the motherboard.
필요한 것
Using the plastic opening tool, open one of the tabs on the bottom of the device.
While keeping the tab open, insert a opening pick in between the opening tool and tab.
Repeat this for the 3 other tabs.
Using the Phillips #2 Screwdriver, remove the seven 9mm screws from the top of the device.
Using the same screwdriver, remove the three 9mm screws from the back of the device.
Using the same screwdriver, remove the one 9mm screw still connecting the small metal clip to the front of the device.
다른 한 분이 해당 안내서를 완성하였습니다.
