소개
This guide will show you how to replace one of the speakers inside the speaker system. Use this if your hear muffled or disrupted sound and believe that a speaker might be blown.
필요한 것
Remove two 6mm Phillips #0 screws.
Remove two 7.5 mm Phillips #0 screws.
Remove seven 4 mm Phillips #0 screws.
이 단계에 사용된 도구:Tweezers$4.99
Using the plastic opening tool, detach the wires connected to the metal plate
Use the plastic opening tool to remove wires connected to the circuit board on the far right.
Use the tweezers to remove wires connected to the circuit board in between the two black wires.
Use the tweezers to press the release tab on the front and back of the plastic white wire head.
Once the tab is pressed on both sides, lift up to slide wire head out of socket.
Gently pry the speaker out from the housing using the metal spudger.
Use wire cutters to cut the red and black wires, or desolder the speaker wires to remove the speaker. See iFixit's guide on How To Solder and Desolder Connections.
다른 4명이 해당 안내서를 완성하였습니다.
