주요 콘텐츠로 건너뛰기
Sony Cyber-Shot DSC-S90 Lens Replacement
필요한 것
  1. Sony Cyber-Shot DSC-S90 Lens Replacement, Batteries: 1 단계, 이미지 1/2 Sony Cyber-Shot DSC-S90 Lens Replacement, Batteries: 1 단계, 이미지 2/2
    • Hold down the "open"button (gray oval with arrow pointing upwards) on the battery port door.
    • While holding the button downwards, slide the door upwards to unlock and open the door.
  2. Sony Cyber-Shot DSC-S90 Lens Replacement: 2 단계, 이미지 1/1
    • Pull open the door and allow the batteries to fall out.
  3. Sony Cyber-Shot DSC-S90 Lens Replacement, Back Case: 3 단계, 이미지 1/2 Sony Cyber-Shot DSC-S90 Lens Replacement, Back Case: 3 단계, 이미지 2/2
    • Remove the 2mm Phillips #00 screw under the battery port door.
    • Remove the 2mm Phillips #00 screw towards the right of the bottom-side of the camera.
  4. Sony Cyber-Shot DSC-S90 Lens Replacement: 4 단계, 이미지 1/2 Sony Cyber-Shot DSC-S90 Lens Replacement: 4 단계, 이미지 2/2
    • Remove the two 2mm Phillips #00 screws (one on each side of the camera).
  5. Sony Cyber-Shot DSC-S90 Lens Replacement: 5 단계, 이미지 1/2 Sony Cyber-Shot DSC-S90 Lens Replacement: 5 단계, 이미지 2/2
    • Use an opening tool to unlock the front case from the main body of the camera. Use the tool on the right side and bottom of the camera with the LCD screen facing you.
  6. Sony Cyber-Shot DSC-S90 Lens Replacement: 6 단계, 이미지 1/1
    • Pull apart the back case from the main body of the camera.
  7. Sony Cyber-Shot DSC-S90 Lens Replacement, Front Case: 7 단계, 이미지 1/1
    • Use an opening tool to unlock the front case from the main body of the camera. Use the tool on the top of the camera.
  8. Sony Cyber-Shot DSC-S90 Lens Replacement: 8 단계, 이미지 1/1
    • Pull apart the front case from the main body of the camera.
  9. Sony Cyber-Shot DSC-S90 Lens Replacement, Top/Side Case: 9 단계, 이미지 1/3 Sony Cyber-Shot DSC-S90 Lens Replacement, Top/Side Case: 9 단계, 이미지 2/3 Sony Cyber-Shot DSC-S90 Lens Replacement, Top/Side Case: 9 단계, 이미지 3/3
    • Release all clips and latches keeping the casing in place using a spudger, opening tool, or screwdriver.
  10. Sony Cyber-Shot DSC-S90 Lens Replacement: 10 단계, 이미지 1/1
    • Now the casing can be removed after all latches have been undone.
  11. Sony Cyber-Shot DSC-S90 Lens Replacement, Battery Terminal: 11 단계, 이미지 1/3 Sony Cyber-Shot DSC-S90 Lens Replacement, Battery Terminal: 11 단계, 이미지 2/3 Sony Cyber-Shot DSC-S90 Lens Replacement, Battery Terminal: 11 단계, 이미지 3/3
    • Disconnect the ribbon cables on top of the battery terminal using a spudger or screwdriver.
  12. Sony Cyber-Shot DSC-S90 Lens Replacement: 12 단계, 이미지 1/1
    • Disconnect the remaining ribbon cable on the side of the camera using a spudger or screwdriver.
  13. Sony Cyber-Shot DSC-S90 Lens Replacement: 13 단계, 이미지 1/1
    • Use a spudger or screwdriver to unhinge the clips. This releases the battery terminal.
  14. Sony Cyber-Shot DSC-S90 Lens Replacement: 14 단계, 이미지 1/1
    • Once the battery terminal is unclipped, pull this ribbon cable out with a spudger or screwdriver to finish freeing the battery terminal.
  15. Sony Cyber-Shot DSC-S90 Lens Replacement: 15 단계, 이미지 1/1
    • Now the battery terminal can be separated from the main body of the camera.
  16. Sony Cyber-Shot DSC-S90 Lens Replacement, Motherboard: 16 단계, 이미지 1/3 Sony Cyber-Shot DSC-S90 Lens Replacement, Motherboard: 16 단계, 이미지 2/3 Sony Cyber-Shot DSC-S90 Lens Replacement, Motherboard: 16 단계, 이미지 3/3
    • Disconnect the three pictured ribbon cables using a spudger or screwdriver.
  17. Sony Cyber-Shot DSC-S90 Lens Replacement: 17 단계, 이미지 1/1
    • Push the clip to the left and lift the motherboard upwards and away from the camera.
  18. Sony Cyber-Shot DSC-S90 Lens Replacement: 18 단계, 이미지 1/2 Sony Cyber-Shot DSC-S90 Lens Replacement: 18 단계, 이미지 2/2
    • Disconnect the two ribbon cables using a spudger or screwdriver.
  19. Sony Cyber-Shot DSC-S90 Lens Replacement: 19 단계, 이미지 1/1
    • Unlatch the clip and lift the motherboard upwards and away from the camera.
  20. Sony Cyber-Shot DSC-S90 Lens Replacement, Flash: 20 단계, 이미지 1/2 Sony Cyber-Shot DSC-S90 Lens Replacement, Flash: 20 단계, 이미지 2/2
    • Release the clips on either side of the connector/ribbon cable using a spudger or screwdriver.
  21. Sony Cyber-Shot DSC-S90 Lens Replacement: 21 단계, 이미지 1/2 Sony Cyber-Shot DSC-S90 Lens Replacement: 21 단계, 이미지 2/2
    • Release the two clips next to the flash using a spudger or screwdriver.
    • Release the clip holding the LED indicator in place using a spudger or screwdriver.
    • Push the LED indicator upwards from below using a spudger or screwdriver.
  22. Sony Cyber-Shot DSC-S90 Lens Replacement: 22 단계, 이미지 1/1
    • After all clips have been undone the flash is free to be removed/replaced.
  23. Sony Cyber-Shot DSC-S90 Lens Replacement, Lens: 23 단계, 이미지 1/1
    • Remove five 2mm Phillips #00 screws surrounding the lens using a screwdriver.
  24. Sony Cyber-Shot DSC-S90 Lens Replacement: 24 단계, 이미지 1/1
    • Release the clip that holds the housing for the flash and LED in place using a spudger.
    • The use of a screwdriver to release the clip as shown in the image is not advised, as any contact with the metal bit with any circuitry could result in a shorted board. Use an ESD safe tool instead!
    • Rotate the housing backwards to free the lens.
  25. Sony Cyber-Shot DSC-S90 Lens Replacement: 25 단계, 이미지 1/1
    • Remove the lens from the camera.
결론
Jonathan Arns
회원 가입일: 10/28/19
745 평판
안내서 8개 작성하였습니다
UMass Dartmouth, Team S4-G5, Saloman Fall 2019 UMass Dartmouth, Team S4-G5, Saloman Fall 2019 회원
UMASSD-SALOMAN-F19S4G5
3 회원들
안내서 20개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 26
전체 시간: 410
