주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Sony Cyber-shot DSC-H2 수리는 저희 서비스 설명서를 사용하십시오.
  1. Sony Cyber-shot DSC-H2 Teardown, Sony Cyber-shot DSC-H2 Teardown: 1 단계, 이미지 1/2 Sony Cyber-shot DSC-H2 Teardown, Sony Cyber-shot DSC-H2 Teardown: 1 단계, 이미지 2/2
    • This is the Sony DSC-H2 we are going to tear down.
    • It's a 6.0mpix, 12x optical zoom compact digital camera.
    • It served well to the point at which the shutter button fell off.
    • To tear it apart, we need a #0 Philips screwdriver only, thats very nice of you, Sony!
  2. Sony Cyber-shot DSC-H2 Teardown: 2 단계, 이미지 1/3 Sony Cyber-shot DSC-H2 Teardown: 2 단계, 이미지 2/3 Sony Cyber-shot DSC-H2 Teardown: 2 단계, 이미지 3/3
    • Almost all cameras have a high voltage circuit and capacitor to power the flash.
    • Before you disassemble any camera, remove the batteries and wait a full day to make sure the capacitor is discharged
    • Never use bare fingers or tools with metal handles near a high voltage capacitor which you are not certain its discharged!
  3. Sony Cyber-shot DSC-H2 Teardown: 3 단계, 이미지 1/2 Sony Cyber-shot DSC-H2 Teardown: 3 단계, 이미지 2/2
    • For safety reasons, find a screwdriver that has a plastic, wooden or other non-conducting handle
    • The second photo shows a spark and a plasma cloud created by rapidly discharging a capacitor similar to the one in this camera. (the picture was taken at the technical university of Łódź, Poland, do not try this at home!)
  4. Sony Cyber-shot DSC-H2 Teardown: 4 단계, 이미지 1/3 Sony Cyber-shot DSC-H2 Teardown: 4 단계, 이미지 2/3 Sony Cyber-shot DSC-H2 Teardown: 4 단계, 이미지 3/3
    • Now, let's start the ceremony!
    • Remove the two screws at the bottom.
    • The two on the right side.
    • And the one on the left side
  5. Sony Cyber-shot DSC-H2 Teardown: 5 단계, 이미지 1/3 Sony Cyber-shot DSC-H2 Teardown: 5 단계, 이미지 2/3 Sony Cyber-shot DSC-H2 Teardown: 5 단계, 이미지 3/3
    • There is one more screw at the right side of the flash lamp
    • These 5 screws are identical, and unique to the outer shell of the camera.
    • We may now remove the back shell, revealing the LCD and rear control panel
    • The body is thick and looks durable
  6. Sony Cyber-shot DSC-H2 Teardown: 6 단계, 이미지 1/3 Sony Cyber-shot DSC-H2 Teardown: 6 단계, 이미지 2/3 Sony Cyber-shot DSC-H2 Teardown: 6 단계, 이미지 3/3
    • Remove the two philips screws, and the two ribbons.
    • The button panel and the LCD is now free.
    • The camera has a 2.0", 85,000 dot LCD
  7. Sony Cyber-shot DSC-H2 Teardown: 7 단계, 이미지 1/3 Sony Cyber-shot DSC-H2 Teardown: 7 단계, 이미지 2/3 Sony Cyber-shot DSC-H2 Teardown: 7 단계, 이미지 3/3
    • Under the LCD, we find a metal screen protecting the logic board.
    • Carefully unlock it at the top and left side
    • We're in
    • Remove all the ribbon cables. There sure is a lot of them.
    • Some of the ribbon cables have "Halogen free" singed on them. That's nice, but we are still not throwing the camera away, not just yet.
  8. Sony Cyber-shot DSC-H2 Teardown: 8 단계, 이미지 1/3 Sony Cyber-shot DSC-H2 Teardown: 8 단계, 이미지 2/3 Sony Cyber-shot DSC-H2 Teardown: 8 단계, 이미지 3/3
    • These two screws hold the logic board.
    • When removing the board, be careful about some remaining ribbon cables.
    • The board is out!
    • On one side we see the AD80080A chip from Analog devices responsible for capturing the analog signal from the CCD
    • On the other side, we see the Sony "Real Imaging Processor" that converts raw photo data into nice and human-viewable .jpg files.
    • The analog cable connecting the CCD to the logic board is screened with some pieces of metal to reduce noise.
  9. Sony Cyber-shot DSC-H2 Teardown: 9 단계, 이미지 1/2 Sony Cyber-shot DSC-H2 Teardown: 9 단계, 이미지 2/2
    • Under the logic board there is this piece of plastic, separating the lens and sensor from the rest of the camera.
    • It comes right out, no screws or whatsoever.
    • Detach the electronic viewfinder atop.
    • The plastic locks hold the lens and screen of the electronic viewfinder together.
  10. Sony Cyber-shot DSC-H2 Teardown: 10 단계, 이미지 1/3 Sony Cyber-shot DSC-H2 Teardown: 10 단계, 이미지 2/3 Sony Cyber-shot DSC-H2 Teardown: 10 단계, 이미지 3/3
    • The viewfinder screen is sooooo smallll!
    • It has 200.000 dots, and about 30mm2 of area
    • That is some insane pixel density, look what happens when the optics used to view this display are pressed against a typical laptop display - you can see the sub-pixels!
  11. Sony Cyber-shot DSC-H2 Teardown: 11 단계, 이미지 1/2 Sony Cyber-shot DSC-H2 Teardown: 11 단계, 이미지 2/2
    • The next two screws hold the lens and sensor module
    • It's out, and it's huge.
    • You can even make it bigger, apply 3 volts to the marked terminals to extend the lens.
  12. Sony Cyber-shot DSC-H2 Teardown: 12 단계, 이미지 1/3 Sony Cyber-shot DSC-H2 Teardown: 12 단계, 이미지 2/3 Sony Cyber-shot DSC-H2 Teardown: 12 단계, 이미지 3/3
    • Remove these two screws to detach the sensor from the lens
    • The sensor has a typical 1/2.5" size. That's not a big sensor.
    • Here you have a 5 polish zloty coin for comparison.
    • 5 polish zloty's is about $1.80, in case you don't grasp the size yet :)
    • The CCD is very shinny.
    • 6 megapixels from a 1 / 2.5" sensor is like expecting 70 megapixels from a 35mm film camera. It's still better then pumping 12 megapixels out of a pinhead sized sensor in mobile phones.
    • Manufacturers, please stop the megapixel war. Thank you.
  13. Sony Cyber-shot DSC-H2 Teardown: 13 단계, 이미지 1/2 Sony Cyber-shot DSC-H2 Teardown: 13 단계, 이미지 2/2
    • The Carl Zeiss lens from the sony camera alongside the lens from a Zorki-6 soviet compact rangefinder from 1960.
    • Unlike the Sony, the Zorka still works, despite being over 40 years older.
    • The back of the Zeiss has significantly more electronics, ribbon cables and servomechanisms than the Zorka lens
  14. Sony Cyber-shot DSC-H2 Teardown: 14 단계, 이미지 1/3 Sony Cyber-shot DSC-H2 Teardown: 14 단계, 이미지 2/3 Sony Cyber-shot DSC-H2 Teardown: 14 단계, 이미지 3/3
    • Lets get back to the body of the camera
    • Lift this plastic lock to remove the hight voltage chip powering the speed light.
    • 3 cables connect this board with the lamp and they are soldered.
    • The capacitor has 320 micro farads of capacity and operates at 330 volts. That's 17.4 joules of potential electric energy, quite much for a speed light.
  15. Sony Cyber-shot DSC-H2 Teardown: 15 단계, 이미지 1/3 Sony Cyber-shot DSC-H2 Teardown: 15 단계, 이미지 2/3 Sony Cyber-shot DSC-H2 Teardown: 15 단계, 이미지 3/3
    • To get to the microphone and top button panel, unscrew these three.
    • Sony made sure that the microphone caches the sound you want, and not internal motor noise, or the sound of the wind. This is actually very impressive work, most camera manufactures don't care that much.
    • Finally the button panel, with the broken shutter button.
  16. Sony Cyber-shot DSC-H2 Teardown: 16 단계, 이미지 1/1
    • That's it. One Sony DSC-H2 in parts. Thanks for reading.
baq
회원 가입일: 10/14/09
305 평판
안내서 3개 작성하였습니다
댓글 7개
Excellent teardown! Great job!
Walter Galan - 답글
Do you have a Sony Cybershot DSC-H2 camera? Did your shutter button just POP OFF? Are you mad that your $400 Cybershot is now useless due to their design flaw?
Well jump on in! We're gonna do something about it. http://www.thepetitionsite.com/1/SonyCla...
Steve Guzman - 답글
Awesome tear-down, saved me $150 bucks and my camera is back!. We love this camera and are so happy to have it working again.
Jason Brown - 답글
I actually went beyond this point and dismantled the lens. Something had come apart inside and it no longer worked. It didn't even retract when I turned off the camera. Can anyone help me with instructions to put it back together? I can't work it out. I figured that the cost to get it repaired would have been more than the camera is now worth, so no harm in trying!!!
Thanks.
Ronald - 답글
My DSC-H2 is not picking up any video It does everything else except I cant see a picture. Much like the Lens coveris left on. Since I see this teardown, what should I look for to correct this?
Denfield McNab - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 24
30일 전: 68
전체 시간: 36,840
