주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-H20 Capacitor Assembly Replacement
필요한 것
  1. Sony Cyber-shot DSC-H20 Capacitor Assembly Replacement, Capacitor Assembly: 1 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-H20 Capacitor Assembly Replacement, Capacitor Assembly: 1 단계, 이미지 2개 중 2개
    • Slide open the cover and remove the battery and the Memory Stick Duo.
    • Return the battery cover to its closed position.
  2. Sony Cyber-shot DSC-H20 Capacitor Assembly Replacement: 2 단계, 이미지 1개 중 1개
    • Remove all three screws from the bottom of the camera.
  3. Sony Cyber-shot DSC-H20 Capacitor Assembly Replacement: 3 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-H20 Capacitor Assembly Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the screws on the left and right sides of the camera.
  4. Sony Cyber-shot DSC-H20 Capacitor Assembly Replacement: 4 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-H20 Capacitor Assembly Replacement: 4 단계, 이미지 2개 중 2개
    • Place the camera upside down with the battery port positioned upward.
    • Slide open the battery port.
  5. Sony Cyber-shot DSC-H20 Capacitor Assembly Replacement: 5 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-H20 Capacitor Assembly Replacement: 5 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-H20 Capacitor Assembly Replacement: 5 단계, 이미지 3개 중 3개
    • Pry the front cover of the camera off with the plastic opening tool.
  6. Sony Cyber-shot DSC-H20 Capacitor Assembly Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the power shutter unit.
    • Caution: Touching the capacitor wires may cause serious injury. Use a capacitor discharge probe to safely rid the capacitors of dangerous charges.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Reuben Martinez
회원 가입일: 02/23/15
333 평판
안내서 2개를 작성함
USF Tampa, Team 1-1, Leahy Winter 2015 USF Tampa, Team 1-1, Leahy Winter 2015 회원
USFT-LEAHY-W15S1G1
3 회원들
안내서 10개를 작성함
댓글 4개
my camera wont turn on i have made shure that my battery is properly put inside and my battery is not dead because i have checked my battery on another camera the lens is stuck and the camera automaticaly turned off saying error now it wont turn on
i have a sony cybershot dsc-h20
please help me
parth patel - 답글
@parth patel
dear patel, I am having same model camera and facing same trouble as you mentioned in your message. I hope you fixed your camera. Please share with me your experience to resolve your camera problem. thanks.
Sivakumar -
some of salty water drops on beach fell on my camera sony dsc-h20 so the camera is not at all starting please can you tell me what problem the camera has ?? and how it will be repaired ?? and please tel me the price ?????
srushti vernekar - 답글
Please help me, My camera’s selection mode is changes automatically and frequently
Sushil Nagar - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 8
전체 시간: 1,641
