주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony Cyber-shot DSC-HX300 LCD Screen Replacement
조회수: 5.8천
통계 보기:
지난 24시간
8
지난 7일:
38
지난 30일:
130
전체 시간:
5,790
댓글: 4
4 guide comments.
Go to guide comments
완료함: 2
2명이 이 안내서를 "완료"로 표시했습니다. 다음은 귀하의 차례입니까?
즐겨찾기: 0
해당 안내서에 좋아요를 누르고 구독한 사람이 아직 없습니다. 첫 번째 주인공이 되시겠습니까?
소요 시간: 30 분 - 1 시간
난이도: 조정
Use this guide to replace the LCD screen of your Sony Cyber-shot DSC-HX300.
The LCD (liquid-crystal display) screen is a flat panel that uses liquid crystals, polarizers, and a backlight or reflector to display images. Without the LCD screen, the user is unable to access some information or the image gallery.
If the LCD screen is not powering on after the LCD/Finder button has been pressed twice, then the screen may need to be replaced.
Before starting this guide, make sure to review the repair page. There may be charging or battery issues that are causing issues rather than the LCD screen itself.
Make sure to turn off your camera before starting this guide.
필요한 것
도구
    1. Sony Cyber-shot DSC-HX300 LCD Screen Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Make sure the camera is powered off
      • Turn the camera upside down. This is a view of the bottom of the camera.
      댓글 쓰기
    2. Sony Cyber-shot DSC-HX300 LCD Screen Replacement: 2 단계, 이미지 1개 중 1개
      • Push battery cover away from the camera.
      댓글 쓰기
    3. Sony Cyber-shot DSC-HX300 LCD Screen Replacement: 3 단계, 이미지 1개 중 1개
      • Push the blue tab that secures the battery. The battery will then spring out.
      댓글 쓰기
    4. Sony Cyber-shot DSC-HX300 LCD Screen Replacement: 4 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-HX300 LCD Screen Replacement: 4 단계, 이미지 2개 중 2개
      • Remove the battery.
      댓글 쓰기
    1. Sony Cyber-shot DSC-HX300 LCD Screen Replacement, LCD Screen: 5 단계, 이미지 1개 중 1개
      • Working on your device while it is turned on may result in electric shock. Make sure to shut down the camera, remove the battery, and unplug your device before you begin.
      • Use a Phillips head screwdriver to remove one 2 cm screw located on the inside portion of the LCD hinge.
      댓글 쓰기
    2. Sony Cyber-shot DSC-HX300 LCD Screen Replacement: 6 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-HX300 LCD Screen Replacement: 6 단계, 이미지 2개 중 2개
      • While using a plastic opening tool, carefully remove the plastic housing that surrounds the hinge.
      댓글 쓰기
    3. Sony Cyber-shot DSC-HX300 LCD Screen Replacement: 7 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-HX300 LCD Screen Replacement: 7 단계, 이미지 2개 중 2개
      • Using a small Phillips head screwdriver, remove the (2) 2 cm screws on the back of the LCD display, as indicated in the photo.
      • Turn the camera on its side to access the last remaining 2 cm Phillips head screw holding the LCD case together.
      댓글 쓰기
    4. Sony Cyber-shot DSC-HX300 LCD Screen Replacement: 8 단계, 이미지 1개 중 1개
      • Remove the plastic cover from the back of the LCD display by simply sliding it up and off of the camera.
      댓글 쓰기
    5. Sony Cyber-shot DSC-HX300 LCD Screen Replacement: 9 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-HX300 LCD Screen Replacement: 9 단계, 이미지 2개 중 2개
      • Using a plastic opening tool, carefully remove the plastic housing that surrounds the LCD display.
      댓글 쓰기
    6. Sony Cyber-shot DSC-HX300 LCD Screen Replacement: 10 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-HX300 LCD Screen Replacement: 10 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-HX300 LCD Screen Replacement: 10 단계, 이미지 3개 중 3개
      • Once the plastic housing is separated, disconnect the ribbon wire located on the back of the LCD display. This can be achieved by pulling up lightly on the brown bar that locks the ribbon wire to the circuit board..
      • Disconnect the remaining two ribbon wires the same way. They are located on the right, rear side of the LCD frame.
      댓글 쓰기
    7. Sony Cyber-shot DSC-HX300 LCD Screen Replacement: 11 단계, 이미지 1개 중 1개
      • Using a small Phillips head screwdriver, remove the last 2 cm screw that mounts the circuit board to the metal LCD display frame.
      댓글 쓰기
    8. Sony Cyber-shot DSC-HX300 LCD Screen Replacement: 12 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-HX300 LCD Screen Replacement: 12 단계, 이미지 2개 중 2개
      • Once the circuit board is removed the replacement parts can be installed in the reverse order.
      댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order. It is important to follow the steps in this order as it may not turn on properly if the user does not follow every step.
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
10다른 기여자
Elizabeth Surface
회원 가입일: 08/26/15
1,477 평판
안내서 9개를 작성함
팀
USF Tampa, Team 4-6, Meier Fall 2015 USF Tampa, Team 4-6, Meier Fall 2015 회원
USFT-MEIER-F15S4G6
4 회원들
안내서 108개를 작성함
4가이드 댓글
my screen is working but in negative effect, any ideas??
wilmer - 답글 공유
Comment réparer la carte circuit imprimé de l'écran? Il y'a un transistor qui reçoit 3.7v et qui laisse rien sortir
Abdoul Traore - 답글 공유
my screen was showing vertical red and green lines but you could read the settings. Now the lcd screen is white. Can the lcd be replaced?
yuclin - 답글 공유
Onde encontro a tela para comprar ?
Diógenes Alonso - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 38
지난 30일: 130
전체 시간: 5,790
