주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-S2100 LCD Replacement
필요한 것
  1. Sony Cyber-shot DSC-S2100 LCD Replacement, LCD: 1 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-S2100 LCD Replacement, LCD: 1 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-S2100 LCD Replacement, LCD: 1 단계, 이미지 3개 중 3개
    • The broken LCD is immediately visible when the camera is turned on.
    • Remove the batteries and, if so equipped, the memory card.
    • Remove the three Philips screws from the bottom of the camera with a Phillips #00 Screwdriver.
  2. Sony Cyber-shot DSC-S2100 LCD Replacement: 2 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-S2100 LCD Replacement: 2 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-S2100 LCD Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the two Philips screws from the right side of the camera.
    • Remove the two Philips screws from the left side of the camera.
    • Split the housing by either using a plastic opening tool, or your finger nails. No excessive force is necessary. For ease of accomplishment, start at the battery compartment.
  3. Sony Cyber-shot DSC-S2100 LCD Replacement: 3 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-S2100 LCD Replacement: 3 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-S2100 LCD Replacement: 3 단계, 이미지 3개 중 3개
    • Once the rear case has been removed, the LCD and frame are easily identified.
    • Fold the LCD to the right, away from the frame.
    • Do not try to remove the LCD yet since the ribbon cable is still connected.
    • Remove the three Philips screws from the LCD frame.
  4. Sony Cyber-shot DSC-S2100 LCD Replacement: 4 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-S2100 LCD Replacement: 4 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-S2100 LCD Replacement: 4 단계, 이미지 3개 중 3개
    • When the LCD frame is removed, the ribbon cable becomes clearly visible.
    • Flip the LCD to its left side. Open the clip of the connector by moving the black lock to the right.
    • Remove the LCD
  5. Sony Cyber-shot DSC-S2100 LCD Replacement: 5 단계, 이미지 1개 중 1개
    • Ensure the screen displayed greets you, once you reassembled your camera
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
oldturkey03
회원 가입일: 09/29/10
837,152 평판
안내서 123개를 작성함
2가이드 댓글
你在哪里?把相机给你帮我挨可以吗
Jeanne - 답글
请问你是在多伦多附近吗?
Jeanne - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 12
지난 30일: 38
전체 시간: 3,491
