주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-TX7 Front Cover Replacement
필요한 것
  1. Sony Cyber-shot DSC-TX7 Front Cover Replacement, Battery: 1 단계, 이미지 1/2 Sony Cyber-shot DSC-TX7 Front Cover Replacement, Battery: 1 단계, 이미지 2/2
    • The battery compartment is located on the bottom of camera.
    • Move the slider from the 'lock' position to the 'open' position.
  2. Sony Cyber-shot DSC-TX7 Front Cover Replacement: 2 단계, 이미지 1/3 Sony Cyber-shot DSC-TX7 Front Cover Replacement: 2 단계, 이미지 2/3 Sony Cyber-shot DSC-TX7 Front Cover Replacement: 2 단계, 이미지 3/3
    • Battery not shown.
    • Pull battery from compartment.
    • Insert newly charged battery into compartment, as shown in diagram (located in compartment).
    • Shut compartment door.
    • Move the slider back to the 'lock' position.
  3. Sony Cyber-shot DSC-TX7 Front Cover Replacement, Front Cover: 3 단계, 이미지 1/1
    • Use the Phillips #00 screwdriver to remove the 4mm length screws. There are 6 screws total.
  4. Sony Cyber-shot DSC-TX7 Front Cover Replacement: 4 단계, 이미지 1/3 Sony Cyber-shot DSC-TX7 Front Cover Replacement: 4 단계, 이미지 2/3 Sony Cyber-shot DSC-TX7 Front Cover Replacement: 4 단계, 이미지 3/3
    • The 4 mm length screws are located on each side and on the bottom of the camera.
    • 2 screws on each side (4 total).
    • 2 screws on bottom.
  5. Sony Cyber-shot DSC-TX7 Front Cover Replacement: 5 단계, 이미지 1/1
    • Gently pry around the front cover using the plastic opening tool.
    • Carefully separate front cover from body of camera.
  6. Sony Cyber-shot DSC-TX7 Front Cover Replacement: 6 단계, 이미지 1/1
    • The front cover is now removed from the camera and the internal hardware is now visible.
    • They front cover will still be connected by a ribbon. Be careful not to break the ribbon.
결론
Leslie Mundell
회원 가입일: 03/18/15
411 평판
안내서 4개 작성하였습니다
Michigan Tech, Team 1-8, Lauer Spring 2015 Michigan Tech, Team 1-8, Lauer Spring 2015 회원
MTU-LAUER-S15S1G8
2 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 15
전체 시간: 366
