주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement
필요한 것
  1. Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement, Battery: 1 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • The battery compartment is located on the bottom of camera.
    • Move the slider from the 'lock' position to the 'open' position.
  2. Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement: 2 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement: 2 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement: 2 단계, 이미지 3개 중 3개
    • Battery not shown.
    • Pull battery from compartment.
    • Insert newly charged battery into compartment, as shown in diagram (located in compartment).
    • Shut compartment door.
    • Move the slider back to the 'lock' position.
  3. Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement, Front Cover: 3 단계, 이미지 1개 중 1개
    • Use the Phillips #00 screwdriver to remove the 4mm length screws. There are 6 screws total.
  4. Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement: 4 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement: 4 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement: 4 단계, 이미지 3개 중 3개
    • The 4 mm length screws are located on each side and on the bottom of the camera.
    • 2 screws on each side (4 total).
    • 2 screws on bottom.
  5. Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement: 5 단계, 이미지 1개 중 1개
    • Gently pry around the front cover using the plastic opening tool.
    • Carefully separate front cover from body of camera.
  6. Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement: 6 단계, 이미지 1개 중 1개
    • The front cover is now removed from the camera and the internal hardware is now visible.
    • They front cover will still be connected by a ribbon. Be careful not to break the ribbon.
  7. Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement, Front Sliding Lens Cover: 7 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement, Front Sliding Lens Cover: 7 단계, 이미지 2개 중 2개
    • Remove the three 4mm length screws located on the inside of the front cover with the Phillips #00 screwdriver.
  8. Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement: 8 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement: 8 단계, 이미지 2개 중 2개
    • Wiggle sliding lens cover after all screws are removed and separate from front cover.
결론
작성자
2다른 기여자 명과 함께
Leslie Mundell
회원 가입일: 03/18/15
414 평판
안내서 4개를 작성함
Michigan Tech, Team 1-8, Lauer Spring 2015 Michigan Tech, Team 1-8, Lauer Spring 2015 회원
MTU-LAUER-S15S1G8
2 회원들
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 12
전체 시간: 986
