주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-TX7 LCD Screen Replacement
필요한 것
  1. Sony Cyber-shot DSC-TX7 LCD Screen Replacement, Battery: 1 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-TX7 LCD Screen Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • The battery compartment is located on the bottom of camera.
    • Move the slider from the 'lock' position to the 'open' position.
  2. Sony Cyber-shot DSC-TX7 LCD Screen Replacement: 2 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-TX7 LCD Screen Replacement: 2 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-TX7 LCD Screen Replacement: 2 단계, 이미지 3개 중 3개
    • Battery not shown.
    • Pull battery from compartment.
    • Insert newly charged battery into compartment, as shown in diagram (located in compartment).
    • Shut compartment door.
    • Move the slider back to the 'lock' position.
  3. Sony Cyber-shot DSC-TX7 LCD Screen Replacement, Front Cover: 3 단계, 이미지 1개 중 1개
    • Use the Phillips #00 screwdriver to remove the 4mm length screws. There are 6 screws total.
  4. Sony Cyber-shot DSC-TX7 LCD Screen Replacement: 4 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-TX7 LCD Screen Replacement: 4 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-TX7 LCD Screen Replacement: 4 단계, 이미지 3개 중 3개
    • The 4 mm length screws are located on each side and on the bottom of the camera.
    • 2 screws on each side (4 total).
    • 2 screws on bottom.
  5. Sony Cyber-shot DSC-TX7 LCD Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Gently pry around the front cover using the plastic opening tool.
    • Carefully separate front cover from body of camera.
  6. Sony Cyber-shot DSC-TX7 LCD Screen Replacement: 6 단계, 이미지 1개 중 1개
    • The front cover is now removed from the camera and the internal hardware is now visible.
    • They front cover will still be connected by a ribbon. Be careful not to break the ribbon.
  7. Sony Cyber-shot DSC-TX7 LCD Screen Replacement, Back Cover: 7 단계, 이미지 1개 중 1개
    • This is the camera with the front cover unscrewed and partially removed.
  8. Sony Cyber-shot DSC-TX7 LCD Screen Replacement: 8 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-TX7 LCD Screen Replacement: 8 단계, 이미지 2개 중 2개
    • Peel the black sticker from the motherboard.
    • Locate the connection ribbon between the front cover and the body of the device.
  9. Sony Cyber-shot DSC-TX7 LCD Screen Replacement: 9 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-TX7 LCD Screen Replacement: 9 단계, 이미지 2개 중 2개
    • Pull the ribbon out of the connection port so that they are completely disconnected.
  10. Sony Cyber-shot DSC-TX7 LCD Screen Replacement: 10 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-TX7 LCD Screen Replacement: 10 단계, 이미지 2개 중 2개
    • Use the plastic opening tool to separate the back cover from the inner hardware.
    • Continue until back cover can be pulled away from inner hardware.
  11. Sony Cyber-shot DSC-TX7 LCD Screen Replacement: 11 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-TX7 LCD Screen Replacement: 11 단계, 이미지 2개 중 2개
    • Remove the back cover so that the back cover is now completely separate from the body of the device.
  12. Sony Cyber-shot DSC-TX7 LCD Screen Replacement, LCD Screen: 12 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-TX7 LCD Screen Replacement, LCD Screen: 12 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-TX7 LCD Screen Replacement, LCD Screen: 12 단계, 이미지 3개 중 3개
    • Pry the LCD screen using the spudger from the back of the camera.
    • Flip screen away from body of device.
  13. Sony Cyber-shot DSC-TX7 LCD Screen Replacement: 13 단계, 이미지 1개 중 1개
    • Lay the camera as shown, so that screen and camera body are next to each other, connected by the yellow ribbon.
    • Peel back the black sticker covering the motherboard.
  14. Sony Cyber-shot DSC-TX7 LCD Screen Replacement: 14 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-TX7 LCD Screen Replacement: 14 단계, 이미지 2개 중 2개
    • Locate the yellow ribbon's connection port.
    • Flip the black bar holding the ribbon in place toward the body of the camera.
  15. Sony Cyber-shot DSC-TX7 LCD Screen Replacement: 15 단계, 이미지 1개 중 1개
    • Pull the yellow ribbon out of the connection port.
    • The LCD screen is now separate from the body of the device.
결론
작성자
2다른 기여자 명과 함께
Leslie Mundell
회원 가입일: 03/18/15
414 평판
안내서 4개를 작성함
Michigan Tech, Team 1-8, Lauer Spring 2015 Michigan Tech, Team 1-8, Lauer Spring 2015 회원
MTU-LAUER-S15S1G8
2 회원들
안내서 14개를 작성함
2가이드 댓글
Very nice guide... Could you provide a dealer where it is possible to find spare parts for Sony cameras?
serhatturkmen - 답글
where can I find a new screen?
John Price - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 23
지난 30일: 68
전체 시간: 2,054
