주요 콘텐츠로 건너뛰기
Sony FDL-220R Watchman Antenna Replacement
필요한 것
  1. Sony FDL-220R Watchman Antenna Replacement, Remove battery cover and batteries: 1 단계, 이미지 1/2 Sony FDL-220R Watchman Antenna Replacement, Remove battery cover and batteries: 1 단계, 이미지 2/2
    • Press down on the textured area and push towards the bottom of the device.
    • Gently remove the battery cover.
    • Remove the three AA batteries.
  2. Sony FDL-220R Watchman Antenna Replacement, Remove screws: 2 단계, 이미지 1/2 Sony FDL-220R Watchman Antenna Replacement, Remove screws: 2 단계, 이미지 2/2
    • Locate the five 5x11mm screws surrounding the battery compartment.
    • Remove screws with a Phillips #00 screwdriver.
  3. Sony FDL-220R Watchman Antenna Replacement, Remove back casing: 3 단계, 이미지 1/2 Sony FDL-220R Watchman Antenna Replacement, Remove back casing: 3 단계, 이미지 2/2
    • Grasp the entire back half of the Watchman's casing.
    • Snap off the casing from the bottom of the device.
    • Gently pull off entire back casing.
    • Buttons may fall out upon opening casing. See the button replacement guide to fix buttons.
  4. Sony FDL-220R Watchman Antenna Replacement, Reattach antenna: 4 단계, 이미지 1/3 Sony FDL-220R Watchman Antenna Replacement, Reattach antenna: 4 단계, 이미지 2/3 Sony FDL-220R Watchman Antenna Replacement, Reattach antenna: 4 단계, 이미지 3/3
    • Locate the two metal tabs which are meant to hold the antenna in place.
    • Pry back the metal tabs with a spudger.
    • Hook the antenna into the metal tab.
    • Ensure that the antenna is fully enclosed in the metal tab.
결론
Sam Putnam
회원 가입일: 10/22/14
484 평판
안내서 4개 작성하였습니다
Baylor, Team 4-5, Williams Fall 2014 Baylor, Team 4-5, Williams Fall 2014 회원
BU-WILLIAMS-F14S4G5
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 19
전체 시간: 462
